6 Replies Latest reply on Aug 30, 2013 11:19 AM by Peter Grainge
    RoboHelp 10 Context Sensitive Help Displays Full Help File, Not the One Topic
    doglvrchik
      I create WebHelp with RoboHelp V10 that contains context sensitive help to be displayed in a software application. When I click on any of the field names in the application, the entire Help file displays with TOC, Index, & Search, tabs but not the field level popup definition the Map ID is mapped to. I moved the RoboHelp V9 generated version files back to the server and the context sensitive help works correctly. Is there something different I need to deploy to the server to display the correct Map ID? I am using IE8 to test both conditions.
      The Map ID's the software application calls to the Map IDs have not changed between the versions of RoboHelp.
