7 Replies Latest reply on Nov 18, 2013 5:55 AM by jasotastic81
    Average Calculation Possible In LiveCycle?
    41globalit
      Hello Adobe Fam,
      I am new to LiveCycle and was wondering if average calcuation works in LiveiCycle at all?  I have a form that I built in Adobe Acrobat that works 100% and calculates dropdowns with no problem.  Manager is now requesting to allow comment boxes to expand as more text is added which i can't figure out in Adobe Acrobat but able to do in LiveCycle with no issue, but the actual average calculation is not workinag at all for the 8 dropdowns now but works 100% in Adobe Acrobat??  One thing this code does is excludes N/A from being counted in calcuation if selected.
      Below is script that came over from the working PDF I built:
      // Average non-N/A values;
      var aFieldNames = new Array("Dropdown1", "Dropdown2","Dropdown3","Dropdown4","Dropdown5","Dropdown6","Dropdown7","Dropdown8");
      // counter for non-N/A values;
      var nCount = 0;
      // variable to sum non-N/A values;
      var nSum = 0;
      // default value for result if no average computed;
      event.value = 0;
      // process array of field names;
      for(i = 0; i < aFieldNames.length; i++) {
      if(this.getField(aFieldNames[i]).valueAsString != "N/A") {
      // field does not have a value of "N/A";
      nCount++; // increment counter
      nSum += Number(this.getField(aFieldNames[i]).value); // add value to sum
      } // end value not N/A;
      } // end loop processing one field;
      // compute the average;
      if(nCount != 0) {
      // non-zero divisor so we can compute the average;
      event.value = nSum / nCount;
      Thanks N advance for any help
        • 1. Re: Average Calculation Possible In LiveCycle?
          otter
          I have the exact same issue. I had to read it twice to make sure I hadn't written it.  I need to have a value for each text selected, then average them then have a text attached to the average (overall score). Will someone please look at this again and assist? Thank you!!!
          • 2. Re: Average Calculation Possible In LiveCycle?
            Dakotajessie
            I would like to know the same thing. Has anybody contacted you.  I can get my fields to calculate and average correctly, I just cannot figure out how to get it to ignore the N/A picked fields in the average.  HELP
            • 3. Re: Average Calculation Possible In LiveCycle?
              41globalit Level 1
              I actually had to go the route of totally removing N/A and keeping the space blank.  So if users want to select N/A, they just have to select the empty space which represents n/a and is also not counted in my final total/average
              • 4. Re: Average Calculation Possible In LiveCycle?
                otter Level 1
                Sound like a reasonable solution.
                • 5. Re: Average Calculation Possible In LiveCycle?
                  jasotastic81 Level 3
                  Here's my solution:
                  I had to set the binding for the dropdowns to numbers. I didn't know what numbers you were using, so I picked "0" for what "N/A" would get, but you can pick whatever. For the form, I made one dropdown and then copy/pasted it however many times I wanted. (In this case 8 to match your example.) I put the code in the calculate event for the text field I was using to report the average.
                  var n = 0;
                  var total = 0;
                  for (var i=0; i<8; i++){
                            if (!xfa.resolveNode("dd1["+i+"]").isNull && xfa.resolveNode("dd1["+i+"]").rawValue != 0){
                                      n++;
                                      total += Number(xfa.resolveNode("dd1["+i+"]").rawValue);
                  this.rawValue = total/n;
                  • 6. Re: Average Calculation Possible In LiveCycle?
                    Dakotajessie Level 1
                    jasotastic81
                    I'm getting close with your scripting, this is what I need my drop down has 9 total entries and calculates only 2 drop boxes fields giving the grade in the total box for the two days.
                    100
                    95
                    85
                    75
                    60
                    40
                    20
                    0
                    N/A
                    I want the 0 to calculate as 0 so that if they get 100 one day and 0 the next the average is 50.  and the N/A if picked then it just puts what they got for the 1st day so n/a and 100 returns 100.  if both are NA then it it should show NA.  Any help would be appreciated.
                    Dakotajessie
                    • 7. Re: Average Calculation Possible In LiveCycle?
                      Alright, then after you've copy/pasted the drop downs, set the data binding values to match the numbers, then use "-1" for N/A. Change the if statement to the following:
                      if(!xfa.resolveNode("dd1[+i+"]").isNull && xfa.resolveNode("dd1["+i+"]").rawValue >= 0){
                      *Note: This could probably be streamlined a little since you only have 2 drop downs, but this will work and allow for later expansion if you add more drop downs later.
