4 Replies Latest reply on Aug 28, 2013 4:10 AM by Bill joy
    How Save File using script ?
    Bill joy
      Hi Expert
      I am using MAC OSX 10.8.3 and InDesign CS5.5
      I use this script to save the InDesign file and run this script using Adobe ExtendScript ToolKit CS5.5
      #target indesign
      var myDocument=app.activeDocument;
      myDocument.save(File("/var/New.indd"));
      But Script give error
      can not save "untitle1.indd" under a new name
      where "untitle1.indd" is created indesign file name.
      Is it Script proble or InDesign problem
      or
      MAC OSX problem ?
      How save file  ?
      Thanks.
        • 1. Re: How Save File using script ?
          BEGINNER_X Level 3
          Hi Bill,
          Please use this code:
          app.activeDocument.save(File("~/Desktop/New.indd"));
          Regards
          Beginner_X
          • 2. Re: How Save File using script ?
            Jump_Over Level 5
            or
            MAC OSX problem ?
            Hi Bill,
            I think it is your path problem. (Are you able to save this file in UI there?)
            Check:
            mFile = new File("/var/New.indd");
            mFile.isValid;
            You can't go forward until above == true;
            You could check how your system records a path using this in ESTK:
            mFile = File.saveDialog();
            select any file and check ESTK console.
            Script is creating a new File object with path you can see (not saving anything), so do it same way.
            If you will pass above with true save a doc using:
            mDoc.save(mFile);
            Jarek
            • 3. Re: How Save File using script ?
              Bill joy Level 1
              Thanks For Reply
              • 4. Re: How Save File using script ?
                Bill joy Level 1
                Thanks Jarek for reply
                Also thenks to Beginner_X
                I found the MAC OSX permission problem.
                If  i use
                #target indesign
                myDocument.save(File("/Applicaion/NewFolder/New.indd"));
                Then Script run successfully run and save "Untitle1.indd" file at location
                /Applicaion/NewFolder/      with name "New.indd".
                But if i use "/var/" path to save the file then it give error
                I think it is  MAC OSX permission problem.
                How solve this MAC OSX permission problem that I save my document file at any location on my MAC system using script
                #target indesign
                myDocument.save(File("---filepath/filename.indd-----"));
