2 Replies Latest reply on Aug 29, 2013 2:41 AM by rheaninja
    Convert AS3 to AS1
    rheaninja
      hi i need help in converting my AS3 code to AS1. it is for a magnifine glass. i want to use it as a movie clip in my timeline. i would like it to work while it is still rolling through the timeline. if you could help me convert it please.
      here is the code:
      //'board' its the main conatiner in which the image resides. The position
      //of 'board' will detrmine the position of your picture within the main movie.
      var board:Sprite=new Sprite();
      this.addChild(board);
      board.x=25;
      board.y=290.25;
      var loader:Loader;
      //The text field that displays loading information. To customize its
      //apearance, got to setUpLoadBox function at the end of the script.
      var infoBox:TextField;
      var image:Bitmap;
      var imageData:BitmapData;
      var glass:Sprite=new Sprite();
      //The size of the magnifying glass. You can change the values as you wish.
      var glassWidth:int=100;
      var glassHeight:int=100;
      var doDrag:Boolean=false;
      var picWidth:Number;
      var picHeight:Number;
      var dataWidth:Number;
      var dataHeight:Number;
      'shrinkFactor' is the factor by which your original (high resolution) image
      will be scaled down for display. The reciprocal of shrinkFactor is the magnifying
      factor. 'shrinkFactor has to be less than 1 for the mangnifying effect to occur.
      var shrinkFactor:Number=1/4;
      var magFactor:Number=1/shrinkFactor;
      setUpLoadBox();
      startApp();
      function startApp():void {
                loader=new Loader();
                //Replace Kazanie_Skargi by the name of your image or the address of your image.
                loader.load(new URLRequest("plant_cell.jpg"));
                //Replace 443 by the size of your high resolution image. Although it
                //will show only for a second or so. In progress display, the total size will
                //be determined automatically.
          infoBox.text="Loading: 0 KB of 146 KB";
          loader.contentLoaderInfo.addEventListener(Event.COMPLETE,initPic);
                loader.contentLoaderInfo.addEventListener(ProgressEvent.PROGRESS,updateInfo);
      function updateInfo(e:ProgressEvent):void {
                infoBox.text="Loading: "+String(Math.floor(e.bytesLoaded/1024))+" KB of "+String(Math.floor(e.bytesTotal/1024))+" KB.";
      function initPic(e:Event):void {
                 image=Bitmap(loader.content);
                 imageData=image.bitmapData;
                 dataWidth=image.width;
                 dataHeight=image.height;
                 image.scaleX=shrinkFactor;
                 image.scaleY=shrinkFactor;
                 picWidth=image.width;
                 picHeight=image.height;
                 board.addChild(image);
                 loader.contentLoaderInfo.removeEventListener(Event.COMPLETE,initPic);
                 loader.contentLoaderInfo.removeEventListener(ProgressEvent.PROGRESS,updateInfo);
                 loader=null;
                 infoBox.text="";
                 infoBox.visible=false;
                 board.addChild(glass);
                 setUpListeners();
        function drawInGlass(a:Number,b:Number):void {
                  var curBd:BitmapData;
                  var curBmp:Bitmap;
                  var xbeg:Number=a-glassWidth/2;
                  var ybeg:Number=b-glassHeight/2;
                  if(xbeg<0){
                            xbeg=0;
                  if(ybeg<0){
                            ybeg=0;
                  if(xbeg>dataWidth-glassWidth){
                            xbeg=dataWidth-glassWidth;
                  if(ybeg>dataHeight-glassHeight){
                            ybeg=dataHeight-glassHeight;
                  curBmp=new Bitmap(new BitmapData(glassWidth,glassHeight));
                  curBmp.bitmapData.copyPixels(imageData,new Rectangle(xbeg,ybeg,glassWidth,glassHeight),new Point(0,0));
                  curBd=curBmp.bitmapData;
                  glass.graphics.clear();
                  glass.graphics.lineStyle();
                  glass.graphics.beginBitmapFill(curBd);
                  glass.graphics.drawRect(0,0,glassWidth,glassHeight);
                  glass.graphics.endFill();
                 function glassClear():void {
         function setUpListeners():void {
                     board.addEventListener(MouseEvent.ROLL_OUT,boardOut);
               board.addEventListener(MouseEvent.MOUSE_MOVE,boardMove);
               board.addEventListener(MouseEvent.MOUSE_DOWN,boardDown);
                           board.addEventListener(MouseEvent.MOUSE_UP,boardUp);
                 function boardOut(e:MouseEvent):void {
                                    doDrag=false;
                                    glassClear();
                                    Mouse.show();
           function boardDown(e:MouseEvent):void {
                                    var locX:Number=board.mouseX;
                              var locY:Number=board.mouseY;
                                    glass.x=locX-glassWidth/2;
                                    glass.y=locY-glassHeight/2;
                                    drawInGlass(magFactor*locX,magFactor*locY);
                                    doDrag=true;
                                    Mouse.hide();
           function boardUp(e:MouseEvent):void {
                                    doDrag=false;
                                    glassClear();
                                    Mouse.show();
           function boardMove(e:MouseEvent):void {
                                               var goodCoords:Point=getGoodCoords(locX,locY);
                                              if(doDrag){
                                              glass.x=goodCoords.x-glassWidth/2;
                                              glass.y=goodCoords.y-glassHeight/2;
                                              locX=goodCoords.x;
                                              locY=goodCoords.y;
                                              e.updateAfterEvent();
         function getGoodCoords(a:Number,b:Number):Point {
                          var goodCoords=new Point();
                          goodCoords.x=a;
                          goodCoords.y=b;
                          if (a < glassWidth/(2*magFactor)){
                                    goodCoords.x=glassWidth/(2*magFactor);
                          if (a > picWidth-glassWidth/(2*magFactor)){
                                    goodCoords.x=picWidth-glassWidth/(2*magFactor);
                          if (b < glassHeight/(2*magFactor)){
                                    goodCoords.y=glassHeight/(2*magFactor);
                          if (b > picHeight-glassHeight/(2*magFactor)){
                                    goodCoords.y=picHeight-glassHeight/(2*magFactor);
                          return goodCoords;
      function setUpLoadBox():void {
                    var infoFormat:TextFormat=new TextFormat();
                          infoBox=new TextField();
                          board.addChild(infoBox);
                          infoBox.x=50;
              infoBox.y=50;
                          infoBox.type=TextFieldType.DYNAMIC;
                          infoBox.autoSize=TextFieldAutoSize.LEFT;
                          infoBox.wordWrap=false;
                          infoBox.border=false;
                          infoBox.background=false;
              infoBox.mouseEnabled=false;
                          infoFormat.color=0xCC0000;
              infoFormat.size=14;
              infoFormat.font="Arial";
              infoBox.defaultTextFormat=infoFormat;
