This content has been marked as final.
Show 1 reply
1. Re: Multiply a Field by a Fixed Number
George_Johnson Aug 28, 2013 6:58 AM (in response to Crystal J27)In the Total Amount field, you can use the following in the Simplified fIeld notation area (Calculate tab):
4.25 * Total\ Pins\ Requested
Note that each space is escaped with a backslash. This wouldn't be needed if you removed the spaces from the field name.
The following custom Calculate JavaScript would also work:
// Custom Calculate script for "Total Amount"
event.value = 4.25 * getField("Total Pins Requested").value;
