3 Replies Latest reply on Jun 10, 2006 9:02 AM by Newsgroup_User
    Quiz Help
    Jadeivy
      I have a quiz that I am using which works fine.
      It was based on a 4 answer multiple choice question.
      I want to add capability for true/false.
      (where action script detects the number of XML answer in a node, and hides the last two choices of the 4 choice question. Thus creating a two answer true/flase question).
      Code before (working):
      if (currentQuestionNumber>quizItems.length)
      gotoAndStop("SummaryScreen");
      var currentQuizItem=quizItems[currentQuestionNumber-1];
      var hasAnswered=false;
      question=currentQuizItem.getQuestion();
      for (var i=1; i<=4; i++)
      _root["answer"+i]=currentQuizItem.getAnswer(i-1);
      stop();
      New code (not workign and causing an infinite loop):
      for (var i=1; i<=currentQuizItem.getNumOfAnswers(); i++)
      _root["answer"+i+"Mark"]._visible=true;
      _root["answer"+i+"Textbox"]._visible=true;
      _root["answer"+i+"Button"]._visible=true;
      for (; i<=4; i++)
      _root["answer"+i+"Mark"]._visible=false;
      _root["answer"+i+"Textbox"]._visible=false;
      _root["answer"+i+"Button"]._visible=false;
      stop();
      this.getNumOfAnswers=function()
      return this.answers.length;
      I can't figure out where the loop error is!
      Anyone?
        • 1. Re: Quiz Help
          Level 7
          for (; i<=4; i++) might better be for (var i=1; i<=4; i++)
          Lon Hosford
          www.lonhosford.com
          Flash, Actionscript and Flash Media Server examples:
          http://flashexamples.hosfordusa.com
          May many happy bits flow your way!
          "Jadeivy" <webforumsuser@macromedia.com> wrote in message
          news:e6d1s9$m5u$1@forums.macromedia.com...
          the
          stop();
          for (; i<=4; i++)
          stop();
          Anyone?
          • 2. Re: Quiz Help
            Jadeivy Level 1
            I tried that originally and I lose all functionality.
            I know it's odd that the variable is not defined, however it was in the tutorial I used to create this.
            http://www.permadi.com/tutorial/flashMXQuiz/index3a.html
            • 3. Re: Quiz Help
              Level 7
              That was causing the infinite loop. Could be an error in the online html
              formatting at the publisher's web site. This is a common risk you take
              copying code from web pages that do not have a downloadable tested solution.
              Contact them for a verification.
              Lon Hosford
              www.lonhosford.com
              news:e6d6ae$qtl$1@forums.macromedia.com...
