0 Replies Latest reply on Aug 28, 2013 9:18 PM by ThuaChi
    I have problem with this script
    ThuaChi Level 1
      From AMS 5 extended license i put an application push RTMP to p2p.rtmfp.net
      then i play from player, it play just about 1 minutes.
      Any people tell me this happen?
      thanks
      Here is my code:
      application.onAppStart = function() {
           * Map of group to file name
          application.startTimes = {};
      application.onConnect = function(client) {
          client.startMatch = function(groupName, matchNo) {
          application.acceptConnection(client);
      application.onPublish = function(client, stream) {
          trace("Handing publish and record request for source stream: " +
                stream.name);
          var nc = new NetConnection();
          nc.onStatus = function(info) {
              netConnectionStatusHandler(nc, info, stream);
          nc.connect("rtmfp://p2p.rtmfp.net/","0f2cce55809a179a454bedae-e99743f11ee7");
      function netConnectionStatusHandler(nc, info, stream) {
          trace("Multicast NetConnection Status: " + info.code);
          switch (info.code) {
          case "NetConnection.Connect.Success":
              initMulticastNetStream(nc, info, stream);
              break;
          case "NetConnection.Connect.Failed":
          case "NetConnection.Connect.Rejected":
          case "NetConnection.Connect.AppShutdown":
              trace("Multicast publish error: " + info.code +
                    ", description: " + info.description);
              break;
          case "NetConnection.Connect.Closed":
              trace("Multicast publish closed: " + info.code +
              break;
                case "NetStream.Connect.Success": // e.info.stream
                                                        case "NetStream.Connect.Rejected": // e.info.stream
                                                        case "NetStream.Connect.Failed": // e.info.stream
                                                        case "NetGroup.Connect.Success": // e.info.group
                                                        case "NetGroup.Connect.Rejected": // e.info.group
                                                        case "NetGroup.Connect.Failed": // e.info.group
                                                        case "NetGroup.Posting.Notify": // e.info.message, e.info.messageID
                                                        case "NetStream.MulticastStream.Reset":
                                                        case "NetStream.Buffer.Full":
                                                        case "NetGroup.SendTo.Notify": // e.info.message, e.info.from, e.info.fromLocal
                                                        case "NetGroup.LocalCoverage.Notify": //
                                                        case "NetGroup.Neighbor.Connect": // e.info.neighbor
                                                        case "NetGroup.Neighbor.Disconnect": // e.info.neighbor
                                                        case "NetGroup.MulticastStream.PublishNotify": // e.info.name
                                                        case "NetGroup.MulticastStream.UnpublishNotify": // e.info.name
                                                        case "NetGroup.Replication.Fetch.SendNotify": // e.info.index
                                                        case "NetGroup.Replication.Fetch.Failed": // e.info.index
                                                        case "NetGroup.Replication.Fetch.Result": // e.info.index, e.info.object
                                                        case "NetGroup.Replication.Request": // e.info.index, e.info.requestID
                                                        default:
        break;
      function initMulticastNetStream(nc, info, stream) {
          var groupSpec = new GroupSpecifier("com.onstream.p2p.0f2cce55809a179a454bedae-e99743f11ee7/"+stream.name);
          groupSpec.serverChannelEnabled = true;
          groupSpec.multicastEnabled = true;
                groupSpec.postingEnabled = true;
          var ns = new NetStream(nc, groupSpec.groupspecWithAuthorizations());
                ns.client = this;
                /*var netGroup = new NetGroup(nc, groupSpec.groupspecWithAuthorizations());*/
          ns.onStatus = function(info) {
              netStreamStatusHandler(info, stream, ns);
      function netStreamStatusHandler(info, stream, ns) {
          trace("NetStream status: " + info.code + " and stream name is " + stream.name);
          // TODO: maybe, uh, do different things here depending on value? who knows!
          if (info.code == "NetStream.Connect.Success") {
              trace('attaching and publishing stream.');
              if (!ns.attach(stream)) {
                  trace("Failed to attach to multicast");
                  return;
              ns.publish("stream","live");
      * Parses the supplied query string, and if valid, returns an Object populated
      * with the name-value pairs contained in the query string. The simple processing
      * here does not preserve multiple name-value pairings having the same name; the
      * last value seen wins. Parameters with no value are mapped to "" (empty String)
      * in the returned Object.
      * @param queryString - A query string portion of a URI, not including the leading
      *                     '?' character.
      * @return An Object containing a key-value mapping for each name-value parameter
      *         defined in the query string; Object is empty if the query string is
      *         invalid.
      function parseQueryString(queryString) {
          var result = {};
          var decoded = "";
          try {
              decoded = decodeURIComponent(queryString);
          catch (e) {
              return result;
          if (decoded.length) {
              var params = decoded.split('&');
              for (var i in params) {
                  var pair = params[i];
                    var sepIndex = pair.indexOf('=');
                  if (sepIndex != -1) {
                      var name = pair.substr(0, sepIndex);
                      result[name] = pair.substr(sepIndex + 1);
                  else
                      result[pair] = "";
          return result;
