1 Reply Latest reply on Aug 29, 2013 12:45 PM by amxyz
    Import custom Key Commands from InDesign CS6 to InDesign CC
    zimlern
      How can I import my custom Key Commands from InDesign CS6 to InDesign CC?
        • 1. Re: Import custom Key Commands from InDesign CS6 to InDesign CC
          amxyz Employee Moderator
          [Moving the thread to the InDesign Forum]
          While the best practice is to recreate any customizations you made from previous versions to the new version to prevent any hiccups, you can certainly try copying the .indk file from the V8 (InDesign CS6) folder to the V9 (CC) folder.
          1. Launch InDesign CS6, Edit > Keyboard Shortcuts > create a new set with all your custom keyboard shortcuts
          2. Launch InDesign CC, Edit > Keyboard Shortcuts > create a new set with the same set name as existed in CS6 but make no modifications
          3. Locate and copy the [set name].indk file in version 8 and replace it in version 9
          4. Repeat the above step for any custom sets you made
          Here's the path to locate the .indk file
          Windows Vista and Windows 7 & 8
          Users\[username]\AppData\Roaming\Adobe\InDesign\[Version]\[Language]\InDesign Shortcut Sets
          Mac OS
          Users/[username]/Library/Preferences/Adobe InDesign/[version]/[language]/InDesign Shortcut Sets
          Please take a look here for more info: http://help.adobe.com/en_US/indesign/cs/using/WS668BC5E2-1E1A-4e75-A69A-44A787B4A5FAa.html #WS57E36B38-B2EB-4255-BAB5-19CCCB4319BFa
          Try it out and let us know if this helps. Thanks!
