1 Reply Latest reply on Jun 11, 2006 10:52 AM by kglad
    AttachMovie Problem
    Caraldur
      I have a movie clip that I attach during runtime. The movieclip called mcRuler has a movieclip inside that I want to use as a button to trigger and function and remove the clip. I have done this with a login window that is attached at the begin. The button-movieclip in that instance works as it should, but one in the mcRuler instance doesn't work. The cursor doesn't change into a hand when you mouse over the clip.
      I have copied the NewRuler movieclip into a new file and added the code to attach the movie and for the onRelease method of the mcSubmitRuler movieclip. It works as it should, so something must be causing a problem in the code above but I amd unable to find the problem.
      HELP!!!
      Here is the code I'm using.
