8 Replies Latest reply on Aug 30, 2013 3:36 AM by Ankit Kanwara.
    How do you underline a drop cap so that subsequent text wraps around it?
      I've found a PDF online where the designer has used large drop caps on a number of occasions that are underlined.
      Obviously this isn't technically difficult, I can add an underline in the Character panel, but the underline appears over the top of the line of text below.
      In the case of the original example, not only does the line of text below appear below the underline on the drop cap, the text adjacent to the right of the drop cap is perfectly lined up with the bottom of both the drop-capped letter and the underline, as if everything is set on the baseline. How is this achieved so acurately?
      Screen Shot 2013-08-30 at 10.44.26.jpgScreen Shot 2013-08-30 at 10.47.07.jpg
