1 Reply Latest reply on Jan 20, 2008 1:38 AM by Ivascu Cristian
    Compilation results
    Trusti
      Hi, I'm new to Flex3 and I like to evaluate it. Deploying sample with PlainHttpService I get an error:
      An error occured on the server. Server error is: 'Error occurred in server thread; nested exception is: java.lang.NoSuchMethodError: flex.license.License.(Ljava/util/Map;Ljava/lang/String;Lflex/license/Logger;)V'
      I've installed Flex Module for Apache. I'm using xammp.
      Can somebody help me?
        • 1. Re: Compilation results
          Ivascu Cristian
          What version of the Flex Module for Apache are you using - providing the location where you downloaded it should be ebough. From the error message I would say that it has something to do with incompatible versions - e.g. trying to use the Flex Module for Apache that was destined for Flex SDK 2 with the Flex SDK 3, or vice-versa. So knowing the versions that you are using will really help.
          Cristian
          P.S. Also make sure that your classpath does not point to the Flex 2 SDK; in this case the module might pick that up instead of the one it installed with.
