1. Re: Error message when attempting to publish page with flash content in cs6
Rob Dillon Sep 1, 2013 3:38 PM (in response to Jeger2011)That alert is just to tell you that you have something in your movie's Library that is set to export for Actionscript. most likely in frame 1. This will cause your movie's download to wait until that object is downloaded to the user's computer. If there is more than one object with this setting, then all of those objects will need to download first before the movie can begin, or to stream.
The problem of your your movie now showing up is completely different. It's impossible to tell where the problem is from looking at the html pages that you provided. The problem may be simple, you may not have the .swf in the proper folder, or the name may not coincide with the swfobject function that you are using.
2. Re: Error message when attempting to publish page with flash content in cs6
Jeger2011 Sep 7, 2013 3:46 AM (in response to Rob Dillon)I have never had this problem before. I attempted to recreate the movie and keep getting the same issue. This has really perplexed me and I am having difficulty determining the source of the problem.
If there is any further guidance you or someone could give me it would be greatly appreciated.
thanks
Brent
