2 Replies Latest reply on Sep 2, 2013 7:11 PM by MichaelN
    Can JavaScript adjust line spacing in annotations?
    Chris Aiken
      I'm trying to write a script that will change the color of all comments in a document to blue.  Right now, I can change all the colors, but the resulting file has text boxes with different line spacing than the original.  This is especially noticable for large blocks of text like the ones put in by Typewriter users with a lot to say.  Is there any way to control line spacing using JavaScript?  I'm using Adobe Acrobat X Pro on a Windows 7 machine.  The code is below.  Thanks for your help!
      //Select all the annotations/comments in the file
      var annots = this.getAnnots()
      //Prepare an array to turn shapes and lines blue
      var myProps = {strokeColor: color.blue};
      //Do the following for each annotation
      for (var j =0; j<annots.length;j++){
           //Turn shapes and lines blue
           annots[j].setProps(myProps);
           //If there is text in the annotation
           if (annots[j].contents !== ""){
           //Prepare an array to edit the text
           var spans = new Array();
           //Do the following for each line of text
           for (var i =0; i<annots[j].richContents.length;i++){
                //Prepare an object to edit the text with
                spans[i] = new Object();
                //Ensure the object is identical to the original in everything except color
                spans[i].text = annots[j].richContents[i].text;
                spans[i].alignment = annots[j].richContents[i].alignment;
                spans[i].fontFamily = annots[j].richContents[i].fontFamily;
                spans[i].textSize = annots[j].richContents[i].textSize;
                //Make the text blue
                spans[i].textColor = color.blue;}
           //Apply the object to the annotation, turning it blue
           annots[j].richContents = spans;
