9 Replies Latest reply on Oct 30, 2013 4:21 PM by d0bermann
    Can’t import any .psd files into after effects.
    Gary Boulter
      Hello all.
      I was using CS5 master collection without issue, for a year.
      Decided to upgrade to the CS6 master collection and that’s when the problems began.
      For example, I can’t import any .psd files into AE.
      All files are saved in RGB mode.
      The previous files were made on CS5.
      I made a new .psd file in CS6 with just a couple of layers on it, couldn’t import that either.
      I’ve tried Ctrl-alt-shift to delete preferences, that had limited success. I can import a file and do a little bit of work on it but as soon as I close the file down and opened it up again, it does not recognise the .psd file.
      The errors I’m getting in AE are many
      For example:
      • After Effects warning: Reading past end of file
      • After Effects error: Could not open intro.psd because it is not a valid Photoshop document
      • After Effects error: Crash in progress. Last logged message:<8104><dynamiclink><5>C:\ProgramFiles\Adobe\Adobe Premiere Pro CS6\Adobe Premiere Pro exe
      • After Effects error: Not enough memory to initialise PSL
      I have un-installed and re-installed many times.
      I’m using Windows 8, with 32ram. Hard drives C: 100mg, D: 2 Tb
      I’ve tried installing on both drives, still the same thing happens.
      Does anyone out there in Adobe Land have any ideas?
      Totally confused
      Cheers,
      Gary.
