2 Replies Latest reply on Sep 3, 2013 2:27 AM by davidDav
    open multiple extensions
      Hi All,
      My script not working for multiple extensions
      var mySourceFolder = Folder("/WATCHED_FOLDER/IN_QXD");
      var quark_files = getFiles(mySourceFolder,[], ".qxp" , ".qxd");
      var indesign_files = getFiles(mySourceFolder,[], ".indd" , ".INDD");
      how can i open the indesign (or) qurak files without finding extensions
      Note: I have Q2ID plugin in indesign
      any help would be appreciated !
      Thanks in advance
        • 1. Re: open multiple extensions
          Trevorׅ Adobe Community Professional
          Hi David
          Regarding the getFiles you have your structure wrong.
          The Folder goes before the get files and not in the brackets and inside the brackets goes a file mask.
          You can look up in the toolguide how to use this.
          One can put a regex as the mask so you can do this:
          var quark_files = mySourceFolder.getFiles (/\.qxp|\.qxd/i);
          The 2 / wrap up the regex the i at the end make it case insensitive (i.e. .qXp is also fine) the | means or and the \ escapes the dots.
          This method will find aliases - short cuts like myFile.qxp.ink :-) but would also find myFile.qxp.think which you might not want it to. If you add a $ after the p and the d it will only find were the file extension end in qxp or qxd so if you wanted to be safe you could do
          var quark_files = mySourceFolder.getFiles (/\.qxp$|\.qxd$/|\.qxd\.ink$|\.qxd\.ink$i);
          (See the toolguide for differences between mac and windows regarding .ink handling but I think my method is safe for all)
          Regarding finding quark files without an extension, I don't have to much of a clue but on Macs you might be able to use file.type but I doubt it.
          Good luck
          • 2. Re: open multiple extensions
            davidDav Level 1
            Hi Trevor,
            You gave me the best method, its working fabulous, also I learned form you
            Thank you very much
