1. Re: Cp7 TTS Dictionary Editor will not open - throws error
Lilybiri Sep 2, 2013 1:08 AM (in response to RodWard)Rod, I have the same error message. I tried it, never used those dictioniaries in CP7 yet (only English available as you know). Same error for all exe-files in that bin directory.
Lieve
2. Re: Cp7 TTS Dictionary Editor will not open - throws error
RodWard Sep 2, 2013 1:50 AM (in response to Lilybiri)Sounds like it's a widespread bug then.
3. Re: Cp7 TTS Dictionary Editor will not open - throws error
Lilybiri Sep 2, 2013 2:16 AM (in response to RodWard)Indeed. Since I never use TTS, it doesn't bother me that much, sometimes I'm a bit egocentric
4. Re: Cp7 TTS Dictionary Editor will not open - throws error
rgcunningham Sep 3, 2013 5:41 AM (in response to RodWard)Interesting that I can edit using the CP6 version of the editor found in C:\Program Files\Adobe\Adobe Captivate 6 x64\VT\Julie\M16\bin and edit the CP7 userdict_eng.csv found in C:\Program Files\Adobe Captivate Voices 7 x64\VT\Julie\M16\data-common\userdict. But I get the same error if I try to use the editor for CP7.
5. Re: Cp7 TTS Dictionary Editor will not open - throws error
Sankaram Sep 4, 2013 2:32 AM (in response to RodWard)Hi Rod,
This is a bug with 64 bit voices. Thanks for letting us know. Win 32 bit voices & Mac voices works fine.
Alternatively can you try following and let us know whether it works or not?
1) Install 32 bit Neo Speech voices.
2) Change the user dict csv file with the 32 bit voices exe.
3) Replace the user dict csv present in 64 bit voices with the modified one in step2.
4) Run the 64 bit Captivate should use the updated csv.
Sankaram.
6. Re: Cp7 TTS Dictionary Editor will not open - throws error
GoodnWise Oct 14, 2013 7:45 AM (in response to Sankaram)Is there an ETA of when this bug in the 64 bit voices will be addressed?
7. Re: Cp7 TTS Dictionary Editor will not open - throws error
RodWard Oct 14, 2013 5:27 PM (in response to GoodnWise)Adobe doesn't usually give answers to this type of question.
If you really need to use a dictionary to edit, you'll have to use the workaround suggested above by Sankaram.
8. Re: Cp7 TTS Dictionary Editor will not open - throws error
rapttus21 May 7, 2014 11:27 PM (in response to RodWard)Can anyone share any link to download Neo speech voices for captivate 7?
9. Re: Cp7 TTS Dictionary Editor will not open - throws error
RodWard May 7, 2014 11:33 PM (in response to rapttus21)Log in here with your Adobe ID:
http://www.adobe.com/cfusion/tdrc/index.cfm?product=captivate
The links for downloading the TTS voices are sort of buried in the paragraph of text that starts off saying: Adobe Captivate comes with a wide variety of assets....
