0 Replies Latest reply on Sep 3, 2013 1:54 AM by _CHLOED
    Relatively simple lingo
    _CHLOED
      I have a page flip animation that I made in falsh but my project have to be primarily based in director so there are elements in director that I add to each page of the book when the page hase flipped. I am quite new to lingo in giredtor so I was hoping to get some help. I have made a list of what I want the script to look like / do. this script will be applied to an invisible square that will be placed (in director) on top of the corner piece that the viewer can click and turn the page. The flash swf file works so that when the user clicks and drags the corner of the page it will turn the page. If the user drags the corner to the other side of the book the page will be turned while the user is dragging. But if the user drags there mouse past a certin point and realeases the mouse the page will finish the animtion of the page turn without the need for the user to drag the corner the whole way. If the mouse is released before this verticle line the corner selected will return to its previous spot. I am refereing to turning a page right to left.
      There is the outline of what I want the script to do. I realise that some of the script i have included is AS 3 just I thought it might be the quickest way to communicate the effect I desire
      the sprites which are the contents of m
      --  the flash swf file is unabled to be interected with by the user
      sprite(channel). mouseEnabled=false
      -- make the elements/contents I have added in director invisible and the mouse can not interact with them
      sprite(channel).visible=true
      sprite(Channel).mouseEnabled=true
      on mouseEnter corner sprite
           -- make the flash swf file able to be interected with by the user
           sprite(channel).mouseEnabled=true
           sprite(channel).visible=false
           sprite(Channel).mouseEnabled=false
      end
      on mouseLeave corner sprite
           if the mouse is Up then
                -- make the flash swf file unable to be interected with by the user
                     sprite(channel).mouseEnabled=false
          else if the mouse is Down then
           end if
      end
      on mouseUp on stage
           -- if the falsh file is mouseEnabled=true i.e. if the person has entered the invisble corner sprite which this script is applied by dragged the corner to outside this corner sprite in a specific area and released their mouse
            if sprite(channel).mouseEnabled=false AND the mouses horizontal location is <= ... AND the mouses horizontal location is >= ... AND the mouses verticle location is >= ...  AND the mouses verticle location is >= ... then
                    wait for two seconds for th page flip animation to finish then go to a marker labled "addresses"
            else if sprite(channel).mouseEnabled=false AND the mouses horizontal location is <= ... AND the mouses horizontal location is >= ... AND the mouses verticle location is >= ...  AND the mouses verticle location is >= ... then
                    wait for 1.5 seconds for the page flip animation to finish then go to a marker labled "addresses"
                    wait for 0.5 seconds for the page flip animation to finish then go to a marker labled "addresses"
           end if
      end
      Thank you very much
      this is only what I think should happen please feel free to make other suggestion I would really appreciate it if someone could write the script
