4 Replies Latest reply on Sep 4, 2013 5:25 AM by Marc Autret
    How to capture document changes using Javascript
    gopaljay78 Level 1
      Can anyone help me on the below request.
      Is it possible to capture document change event through Javascript.
      For example,
      If i delete a word, then the event should be triggered and alert should be shown as "Word is deleted"
      If i make a word as Bold style, then the event should be triggered and alert should be shows as "Formatting changed".
      Gopal
        • 2. Re: How to capture document changes using Javascript
          Vamitul Level 4
          sort of yes.
          have a look at indesign's events, particulary: AFTER_SELECTION_ATTRIBUTE_CHANGED and AFTER_SELECTION_CHANGED
          • 3. Re: How to capture document changes using Javascript
            Pickory Level 3
            Hello,
            In the plugin SDK there is a very nice example.
            //AfterSelectionAttributeChanged.jsx
            //An InDesign CS5 JavaScript
            //Shows how to detect changes to the attributes of the selection. In this example,
            //we'll check the fill and stroke color of the selection. If either property has been
            //set to the "Registration" color, we'll display an alert when/if the attributes
            //of the selection change.
            #targetengine "session"
            main();
            function main(){
                      mySetup();
                      mySnippet();
                      myTeardown();
            function mySetup(){
            function mySnippet(){
                      //Add an event listener that checks the color of the selection.
                      //<fragment>
                      var myDocument = app.documents.add();
                      myDocument.eventListeners.add("afterSelectionAttributeChanged", myCheckForRegistration);
                      //</fragment>
            function myTeardown(){
            //<fragment>
            function myCheckForRegistration(myEvent){
                      var myRegistrationSwatchUsed = false;
                      if(app.selection.length != 0){
                                for(var myCounter = 0; myCounter < app.selection.length; myCounter++){
                                          if(
                                                              app.documents.item(0).selection[myCounter].fillColor == app.documents.item(0).swatches.item("Registration")
                                                              app.documents.item(0).selection[myCounter].strokeColor == app.documents.item(0).swatches.item("Registration")
                                                    myRegistrationSwatchUsed = true;
                      if(myRegistrationSwatchUsed == true){
                                alert("The Registration swatch is applied to some of the\robjects in the selection. Did you really intend to apply this swatch?");
            //</fragment>
