5 Replies Latest reply on Jun 17, 2015 10:42 AM by rafals18850831
    Why is Vanishing Point filter in the latest Photoshop CC creating PNGs that do not match the planes?
    SethPerkins
      Hi Everyone,
      I've scoured the forums, as well as external sites, but not finding a solution.
      Tried tech support, their ideas didn't pan out. Would greatly appreciate some guidance.
      Every time I try to use VPE, the resulting mesh is fine (the dxf), but the PNGs
      do not match the drawn planes at all
      For example, I'll use a file from wikimedia. (all images re-compressed for the forum)
      I draw the right wall, make sure it is blue, then pull the floor.
      Pull the floor and the left wall.
      Pull the back ground (hard to see in the compressed image, but it is there).
      Pull the ceiling.
      The completed planes.  Right wall was drawn, remaining were each
      pulled out the of the previous plane.  All blue.  Entire image is covered.
      Importing the VPE into After Effects CC.  Note the wonky textures.
      Here are the actual textures (original PNGs compressed into JPEG for posting).
      This is the background piece, note how the section of the image doesn't align at
      all with the plane I drew.
      Hope this issue is clear to all.  The mesh looks fine to me, just the PNGs are off.
      I've successfully used the Vanishing Point filter extensively in previous versions of Photoshop.
      I'm currently using Photoshop CC on OSX 10.8.4 running on a 15" PowerBook Retina.
      I've tried the following to no avail:
      • differing JPEGs
      • drawing the floor first
      • drawing the first surface counter-clockwise and clockwise : )
      • ensured all planes are blue
      • disabled graphics acceleration under prefererences
      • completed uninstalled Photoshop and reinstalled with clean performance/preference settings (did not import any previous settings).
        • removed the "Adobe Photoshop CC Settings" folder as well.
      • Tried exporting a DXF, again mesh looks great, textures are wrong.
      Ideas are appreciated because right now, I'm stuck : )
      System Info below:
      Adobe Photoshop Version: 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00) x64
      Operating System: Mac OS 10.8.4
      System architecture: Intel CPU Family:6, Model:58, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
      Physical processor count: 4
      Logical processor count: 8
      Processor speed: 2600 MHz
      Built-in memory: 16384 MB
      Free memory: 9045 MB
      Memory available to Photoshop: 14117 MB
      Memory used by Photoshop: 70 %
      Image tile size: 1024K
      Image cache levels: 4
      OpenGL Drawing: Enabled.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      OpenGL Allow Old GPUs: Not Detected.
      OpenCL Version: 1.2 (Apr 25 2013 18:32:06)
      OpenGL Version: 2.1
      Video Rect Texture Size: 16384
      OpenGL Memory: 992 MB
      Video Card Vendor: NVIDIA Corporation
      Video Card Renderer: NVIDIA GeForce GT 650M OpenGL Engine
      Display: 1
      Main Display
      High DPI Monitor
      Display Depth: 32
      Display Bounds: top=0, left=0, bottom=900, right=1440
      Video Renderer ID: 16918087
      Video Card Memory: 1024 MB
      Serial number: 90970592741803664300
      Application folder: /Applications/Adobe Photoshop CC/
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Macintosh HD, 373.3G, 65.1G free
      Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/
      Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-ins/
      Installed components:
         adbeape.framework   adbeape   3.4.0.29366   0.1160850
         AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.30746   79.535742
         adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
         AdobeACE.framework   AdobeACE   2.20.02.30665   79.535293
         AdobeAGM.framework   AdobeAGM   4.30.19.30830   79.536232
         AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
         AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
         AdobeBIB.framework   AdobeBIB   1.2.03.30665   79.535293
         AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.535293
         AdobeCoolType.framework   AdobeCoolType   5.13.00.30665   79.535293
         AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
         AdobeExtendScript.framework   AdobeExtendScript   4.5.5.30746   79.535742
         AdobeJP2K.framework   AdobeJP2K   1.2.2.29712   79.248139
         AdobeLinguistic.framework      19061
         AdobeMPS.framework   AdobeMPS   5.8.1.30604   79.535029
         AdobeOwl.framework   AdobeOwl   5.0.13   79.533484
         AdobePDFL.framework   AdobePDFL   10.0.1.30505   79.499517
         AdobePDFSettings.framework   AdobePDFSettings   1.4
         AdobePIP.framework   AdobePIP   7.0.0.1768
         AdobeScCore.framework   AdobeScCore   4.5.5.30746   79.535742
         AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
         AdobeXMP.framework   AdobeXMPCore   79.151481   79.151481
         AdobeXMPFiles.framework   AdobeXMPFiles   79.151481   79.151481
         AdobeXMPScript.framework   AdobeXMPScript   79.151481   79.151481
         ahclient.framework   ahclient   1.8.0.31
         aif_core.framework   AdobeAIF   5.0.00   79.534508
         aif_ocl.framework   AdobeAIF   5.0.00   79.534508
         aif_ogl.framework   AdobeAIF   5.0.00   79.534508
         AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
         amtlib.framework   amtlib   7.0.0.169
         boost_date_time.framework   boost_date_time   7.0.0.0
         boost_signals.framework   boost_signals   7.0.0.0
         boost_system.framework   boost_system   7.0.0.0
         boost_threads.framework   boost_threads   7.0.0.0
         Cg.framework   NVIDIA Cg
         CIT.framework   CIT   2.1.6.30158   151334
         CITThreading.framework   CITThreading   2.1.6.30158   151334
         dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
         dvacore.framework   dvacore   7.0.0.0
         dvamarshal.framework   dvamarshal   7.0.0.0
         dvamediatypes.framework   dvamediatypes   7.0.0.0
         dvaplayer.framework   dvaplayer   7.0.0.0
         dvatransport.framework   dvatransport   7.0.0.0
         dvaunittesting.framework   dvaunittesting   7.0.0.0
         dynamiclink.framework   dynamiclink   7.0.0.0
         FileInfo.framework   FileInfo   79.151561   79.151561
         filter_graph.framework   AdobeAIF   5.0.00   79.534508
         ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
         ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
         LogSession.framework   LogSession   2.1.2.1756
         mediacoreif.framework   mediacoreif   7.0.0.0
         patchmatch.framework   AdobePatchMatch   1.1.00.1   1.
         PlugPlugOwl.framework   PlugPlugOwl   4.0.1.34
         UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
         WRServices.framework
      Required plug-ins:
         3D Studio 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
         Accented Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Adaptive Wide Angle 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
         Angled Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Average 14.0 20130423.r.221 2013/04/23:23:00:00  ©1993-2013 Adobe Systems Incorporated - from the file “Average.plugin”
         Bas Relief 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         BMP 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Camera Raw 8.1 (43), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
         Camera Raw Filter 8.1 (43), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
         Chalk & Charcoal 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Chrome 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Cineon 14.0 20130423.r.221 2013/04/23:23:00:00  ©2002-2013 Adobe Systems Incorporated - from the file “Cineon.plugin”
         Clouds 14.0 20130423.r.221 2013/04/23:23:00:00  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
         Collada DAE 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
         Color Halftone 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Colored Pencil 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         CompuServe GIF 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Conté Crayon 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Craquelure 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Crop and Straighten Photos 14.0 20130423.r.221 2013/04/23:23:00:00  ©2003-2013 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
         Crop and Straighten Photos Filter 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Crosshatch 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Crystallize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Cutout 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Dark Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         De-Interlace 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Dicom 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “dicom.plugin”
         Difference Clouds 14.0 20130423.r.221 2013/04/23:23:00:00  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
         Diffuse Glow 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Displace 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Dry Brush 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Eazel Acquire 14.0 20130423.r.221 2013/04/23:23:00:00  ©1997-2013 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
         Embed Watermark NO VERSION - from the file “DigiSign.plugin”
         Entropy 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         Extrude 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         FastCore Routines 14.0 20130423.r.221 2013/04/23:23:00:00  ©1990-2013 Adobe Systems Incorporated - from the file “FastCore.plugin”
         Fibers 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Film Grain 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Filter Gallery 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Flash 3D 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
         Fresco 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Glass 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Glowing Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Google Earth 4 KMZ 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
         Graphic Pen 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Halftone Pattern 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         HDRMergeUI 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
         IFF Format 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Ink Outlines 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         JPEG 2000 14.0 20130423.r.221 2013/04/23:23:00:00  ©2001-2013 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
         Kurtosis 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         Lens Blur 14.0, Copyright © 2002-2013 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
         Lens Correction 14.0, Copyright © 2002-2013 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
         Lens Flare 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Liquify 14.0, Copyright © 2001-2013 Adobe Systems Incorporated - from the file “Liquify.plugin”
         Matlab Operation 14.0 20130423.r.221 2013/04/23:23:00:00  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
         Maximum 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         Mean 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         Measurement Core 14.0 20130423.r.221 2013/04/23:23:00:00  ©1993-2013 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
         Median 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         Mezzotint 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Minimum 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         MMXCore Routines 14.0 20130423.r.221 2013/04/23:23:00:00  ©1990-2013 Adobe Systems Incorporated - from the file “MMXCore.plugin”
         Mosaic Tiles 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Multiprocessor Support 14.0 20130423.r.221 2013/04/23:23:00:00  ©1990-2013 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
         Neon Glow 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Note Paper 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         NTSC Colors 14.0 20130423.r.221 2013/04/23:23:00:00  ©1993-2013 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
         Ocean Ripple 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Oil Paint 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
         OpenEXR 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Paint Daubs 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Palette Knife 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Patchwork 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Paths to Illustrator 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         PCX 14.0 20130423.r.221 2013/04/23:23:00:00  ©1989-2013 Adobe Systems Incorporated - from the file “PCX.plugin”
         Photocopy 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Photoshop 3D Engine 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
         Picture Package Filter 14.0 20130423.r.221 2013/04/23:23:00:00  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
         Pinch 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Pixar 14.0 20130423.r.221 2013/04/23:23:00:00  ©1989-2013 Adobe Systems Incorporated - from the file “Pixar.plugin”
         Plaster 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Plastic Wrap 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         PNG 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Pointillize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Polar Coordinates 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Portable Bit Map 14.0 20130423.r.221 2013/04/23:23:00:00  ©1989-2013 Adobe Systems Incorporated - from the file “PBM.plugin”
         Poster Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Radial Blur 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Radiance 14.0 20130423.r.221 2013/04/23:23:00:00  ©2003-2013 Adobe Systems Incorporated - from the file “Radiance.plugin”
         Range 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         Read Watermark NO VERSION - from the file “DigiRead.plugin”
         Reticulation 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Ripple 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Rough Pastels 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Save for Web 14.0, Copyright © 1999-2013 Adobe Systems Incorporated - from the file “Save for Web.plugin”
         ScriptingSupport 13.0, Copyright © 2013 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
         Shake Reduction 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
         Shear 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Skewness 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         Smart Blur 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Smudge Stick 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Solarize 14.0 20130423.r.221 2013/04/23:23:00:00  ©1993-2013 Adobe Systems Incorporated - from the file “Solarize.plugin”
         Spatter 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Spherize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Sponge 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Sprayed Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Stained Glass 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Stamp 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Standard Deviation 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         STL 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
         Sumi-e 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Summation 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         Targa 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Texturizer 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Tiles 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Torn Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Twirl 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Underpainting 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Vanishing Point 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
         Variance 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
         Water Paper 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Watercolor 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Wave 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Wavefront|OBJ 14.0 20130423.r.221 2013/04/23:23:00:00  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
         Wind 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Wireless Bitmap 14.0 20130423.r.221 2013/04/23:23:00:00  ©1989-2013 Adobe Systems Incorporated - from the file “WBMP.plugin”
         ZigZag 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
      Optional and third party plug-ins: NONE
      Plug-ins that failed to load: NONE
      Flash:
         Kuler
         Adobe Exchange
      Installed TWAIN devices: NONE
