3 Replies Latest reply on Sep 3, 2013 11:30 AM by Dov Isaacs
    Convert CMYK to Pantone
    ArleneNYC
      How can I convert CMYK to a specific Pantone color and black (2 color job) in InDesign CS5?
        • 1. Re: Convert CMYK to Pantone
          BobLevine MVP & Adobe Community Professional
          Add the spot color you want to the swatches. Delete the swatch you want
          to replace it with.
          You'll be prompted to choose a replacement. Choose the pantone color.
          • 2. Re: Convert CMYK to Pantone
            There isn't a way to directly convert. You can get all of the colors in a document into the swatches panel via Add Unnamed Colors. From there you can edit document colors to use only the 2 spot colors. And you would have to open any placed images and convert them to Duotone or Monotone
            • 3. Re: Convert CMYK to Pantone
              Dov Isaacs Adobe Employee
              Implied with both Bob and Rob's responses is the assumption that you are disciplined enough to define swatches for all the colors you explicitly use in a document. InDesign doesn't require that you define all colors with swatches just like InDesign doesn't require use of paragraph, character, table, cell, and object styles. Good design discipline does pay off however when you need to do color substitutions, either with spot colors or even other process colors.
                        - Dov
