2 Replies Latest reply on Sep 3, 2013 11:16 PM by FlexCoderCali123
    messagebroker/amf Throwing 404 error on domain Server
    FlexCoderCali123 Level 1
      I am Working with blazeDs and Java using Remote object using 4.5 Flex SDK , My application is running perfect locally like when applications hits http://localhost:8400/GerenciaUsuario/messagebroker/amf it is working fine but when i deploy my application on Domain Server http://HostName/GerenciaUsuario/messagebroker/amf is throwing 404 Exception can some one please help me ....
        • 1. Re: messagebroker/amf Throwing 404 error on domain Server
          吃牛排的羊 Level 1
          looks like the cofiguration is not right. check you web.xml, services-config.xml.
          can you remote debug on your servlet which url-pattern is /messageborker/amf/ ?
          • 2. Re: messagebroker/amf Throwing 404 error on domain Server
            Thanks for your reply the Web.xml File i am using is
            <?xml version="1.0" encoding="UTF-8"?>
            <!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN" "http://java.sun.com/dtd/web-app_2_3.dtd">
            <web-app>
                <display-name>BlazeDS</display-name>
                <description>BlazeDS Application</description>
                <!-- Http Flex Session attribute and binding listener support -->
                <listener>
                    <listener-class>flex.messaging.HttpFlexSession</listener-class>
                </listener>
                <!-- MessageBroker Servlet -->
                <servlet>
                    <servlet-name>MessageBrokerServlet</servlet-name>
                    <display-name>MessageBrokerServlet</display-name>
                    <servlet-class>flex.messaging.MessageBrokerServlet</servlet-class>
                    <init-param>
                        <param-name>services.configuration.file</param-name>
                        <param-value>/WEB-INF/flex/services-config.xml</param-value>
                   </init-param>
                    <load-on-startup>1</load-on-startup>
                </servlet>
            <!-- begin rds
            end rds -->
                <servlet>
                    <servlet-name>RDSDispatchServlet</servlet-name>
                                <display-name>RDSDispatchServlet</display-name>
                    <servlet-class>flex.rds.server.servlet.FrontEndServlet</servlet-class>
                                <init-param>
                                          <param-name>useAppserverSecurity</param-name>
                                          <param-value>false</param-value>
                                </init-param>
                    <load-on-startup>10</load-on-startup>
                </servlet>
                <servlet-mapping id="RDS_DISPATCH_MAPPING">
                    <url-pattern>/CFIDE/main/ide.cfm</url-pattern>
                </servlet-mapping>
                <servlet-mapping>
                    <url-pattern>/messagebroker/*</url-pattern>
                </servlet-mapping>
                <welcome-file-list>
                    <welcome-file>index.html</welcome-file>
                    <welcome-file>index.htm</welcome-file>
                </welcome-file-list>
                <!-- for WebSphere deployment, please uncomment -->
                <resource-ref>
                    <description>Flex Messaging WorkManager</description>
                    <res-ref-name>wm/MessagingWorkManager</res-ref-name>
                    <res-type>com.ibm.websphere.asynchbeans.WorkManager</res-type>
                    <res-auth>Container</res-auth>
                    <res-sharing-scope>Shareable</res-sharing-scope>
                </resource-ref>
            </web-app>
            and Services-config.xml iam using is
            <services-config>
                <services>
                    <service-include file-path="remoting-config.xml" />
                </services>
                <security>
                    <login-command class="flex.messaging.security.TomcatLoginCommand" server="Tomcat"/>
                </security>
                <channels>
                    <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                        <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
                    </channel-definition>
                    <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
                        <endpoint url="https://localhost:8400/GerenciaUsuario/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
                        <properties>
                            <add-no-cache-headers>false</add-no-cache-headers>
                        </properties>
                                <channel-definition id="my-streaming-amf" class="mx.messaging.channels.StreamingAMFChannel">
                                            <endpoint url="https://localhost:8400/GerenciaUsuario/messagebroker/amfsecure/streamingamf" class="flex.messaging.endpoints.StreamingAMFEndpoint" />
                                           <properties>
                                                      <idle-timeout-minutes>0</idle-timeout-minutes>
                                                      <max-streaming-clients>10</max-streaming-clients>
                                                      <server-to-client-heartbeat-millis>5000</server-to-client-heartbeat-m illis>
                                                     <user-agent-settings>
        <user-agent match-on="MSIE" kickstart-bytes="2048" max-streaming-connections-per-session="3" />
        <user-agent match-on="Firefox" kickstart-bytes="2048" max-streaming-connections-per-session="3" />
                                                      </user-agent-settings>
                                          </properties>
                    <channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel">
                        <endpoint url="http://localhost:8400/GerenciaUsuario/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
                        <properties>
                            <polling-enabled>true</polling-enabled>
                            <polling-interval-seconds>4</polling-interval-seconds>
                        </properties>
                    <channel-definition id="my-http" class="mx.messaging.channels.HTTPChannel">
                        <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/http" class="flex.messaging.endpoints.HTTPEndpoint"/>
                    <channel-definition id="my-secure-http" class="mx.messaging.channels.SecureHTTPChannel">
                        <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/httpsecure" class="flex.messaging.endpoints.SecureHTTPEndpoint"/>
                        <properties>
                        </properties>
                </channels>
                <logging>
                    <target class="flex.messaging.log.ConsoleTarget" level="Error">
                        <properties>
                            <prefix>[BlazeDS] </prefix>
                            <includeDate>false</includeDate>
                            <includeTime>false</includeTime>
                            <includeLevel>false</includeLevel>
                            <includeCategory>false</includeCategory>
                        </properties>
                        <filters>
                            <pattern>Endpoint.*</pattern>
                            <pattern>Service.*</pattern>
                            <pattern>Configuration</pattern>
                        </filters>
                    </target>
                </logging>
                <system>
                    <redeploy>
                        <enabled>false</enabled>
                        <watch-interval>20</watch-interval>
                        <watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/proxy-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/messaging-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/data-management-config.xml</watch-file>
                        <touch-file>{context.root}/WEB-INF/web.xml</touch-file>
                    </redeploy>
                </system>
            </services-config>
