• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Handling successive versions of the same help project in VSS
Explorer ,
Jan 10, 2008 Jan 10, 2008
If I understand it correctly, RHX5 always gets the most-recent version of a version-controlled project from Visual SourceSafe. Sometimes, however, I may want to build an older, labeled version of the project. By using VSS directly, I think I would be able to check the old labeled version out to a working directory. But my concern is that if I tried to open the project in RH it will get confused and start checking out the latest version again. If so, can this be avoided?
Another way of asking the same question is this: Suppose I write a help system for Release 1 of my application, put it in VSS and label it accordingly. Then I start updating the project for Release 2. If it turns out I have to make some fixes to the Release 1 version, ignoring the changes that relate to work on Release 2, what's the best way of handling this?
Views
295
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advisor ,
Either maintain both versions in the same RH project with conditional tags, or copy V1 and name it V2. Then add V2 to VSS in a completely separate directory (or folder, or library, or whatever VSS calls them).
Leon
Votes
Translate
Translate
Report
Report
Explorer ,
That noise you can hear is the sound of me kicking myself. Conditional tags. Of course! I was so fixated on the VSS thing that I overlooked the obvious.
Votes
Translate
Translate
Report
Report
Advisor ,
Jan 11, 2008 Jan 11, 2008
LATEST
Glad to help you on the road to fixationless authoring!
Leon
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
