15 Replies Latest reply on Sep 7, 2013 5:08 AM by Asembler1387900
    AVC H264 720p60 video with AC-3 asynchronous after exporting as AVCHD using Pre11
    Asembler1387900
      Dear community,
      I am currently facing a problem concerning asynchronous video and sound after rendering AVC files including H264 codec at 720p60 and AC3 sound as well as multiple stereo tracks.
      The video is recorded using Hauppauge Hauppauge HVR-5500HD to record DVB-C.
      After editing (only cutting, no effects) and exporting as AVCHD 720p60, vbr 2pass, I get gradually increasing asynchronity. Some exports are at the beginning perfecty synchronous and get more and more asynchronous (until reaching a peak of approximately 5 minutes delay of video at a 2 hours export), others have the delay at the beginning and are perfecly synchronous at the end.
      However, that issue doesn't occur with all souce files, only with some random ones! (Unfortunately the most!)
      Here is the output of the souce video using MediaInfo (1 example out of many similar ones):
      General
      Complete name :anything.ts
      Format :MPEG-TS
      File size :7.95 GiB
      Duration :1h 59mn
      Overall bit rate mode :Variable
      Overall bit rate :9 489 Kbps
      Network name :
      Video
      Menu ID :5001 (0x1389)
      Format :AVC
      Format/Info :Advanced Video Codec
      Format profile :High@L4.0
      Format settings, CABAC :Yes
      Format settings, ReFrames :4 frames
      Codec ID :27
      Duration :1h 59mn
      Bit rate :8 244 Kbps
      Width :1 280 pixels
      Height :720 pixels
      Display aspect ratio :16:9
      Frame rate :50.000 fps
      Standard :Component
      Color space :YUV
      Chroma subsampling :4:2:0
      Bit depth :8 bits
      Scan type :Progressive
      Bits/(Pixel*Frame) :0.179
      Stream size :6.90 GiB (87%)
      Color primaries :BT.709
      Transfer characteristics :BT.709
      Matrix coefficients :BT.709
      Audio #1
      Format :MPEG Audio
      Format version :Version 1
      Format profile :Layer 2
      Mode :Joint stereo
      Codec ID :3
      Duration :1h 59mn
      Bit rate mode :Constant
      Bit rate :160 Kbps
      Channel(s) :2 channels
      Sampling rate :48.0 KHz
      Compression mode :Lossy
      Delay relative to video :-815ms
      Stream size :137 MiB (2%)
      Language :German
      Language, more info :Clean effects
      Audio #2
      Format :MPEG Audio
      Mode :Joint stereo
      Codec ID :3
      Duration :1h 59mn
      Bit rate :160 Kbps
      Language :English
      Audio #3
      Format :AC-3
      Format/Info :Audio Coding 3
      Mode extension :CM (complete main)
      Format settings, Endianness :Big
      Codec ID :6
      Duration :1h 59mn
      Bit rate :448 Kbps
      Channel positions :Front: L R
      Bit depth :16 bits
      Delay relative to video :-748ms
      Stream size :384 MiB (5%)
      Language :German
      Text #1
      ID :2101 (0x835)-100
      Format :Teletext
      Language :German
      Text #2
      ID :2101 (0x835)-777
      Format :Teletext Subtitle
      Language :German
      Menu
      Duration :1h 59mn
      List :2001 (0x7D1) (AVC) / 2011 (0x7DB) (MPEG Audio, German) / 2012 (0x7DC) (MPEG Audio, English) / 2041 (0x7F9) (AC-3, German) / 2101 (0x835) () / 8001 (0x1F41) ()
      Language :/ German / English / German
      UTC 2013-08-04 18:00:00 :de:ZiB 20 / de: / news/current affairs /  / 00:15:00 /
      UTC 2013-08-04 18:15:00 :de:Geld schlÈaft nicht / de: / movie/drama /  / 02:05:00 /
      UTC 2013-08-04 20:20:00 :de:ZiB Flash / de: / news/current affairs /  / 00:10:00 / Running
      UTC 2013-08-04 20:30:00 :de:X-Men Origins: Wolverine / de: / science fiction/fantasy/horror /  / 01:45:00 / Not running
      UTC 2013-08-04 22:15:00 :de:Navy CIS: L.A. / de: / reserved for future use /  / 00:40:00 / Running
      UTC 2013-08-04 22:55:00 :de:CSI: Miami / de: / reserved for future use /  / 00:45:00 / Not running
      UTC 2013-08-04 23:40:00 :de:CSI: Miami / de: / reserved for future use /  / 00:40:00 /
      UTC 2013-08-05 00:20:00 :de:Geld schlÈaft nicht / de: / movie/drama /  / 02:05:00 /
      UTC 2013-08-05 02:25:00 :de:Navy CIS: L.A. / de: / reserved for future use /  / 00:40:00 /
      UTC 2013-08-05 03:05:00 :de:Alles Betty / de: / reserved for future use /  / 00:50:00 /
      UTC 2013-08-05 03:55:00 :de:Seitenblicke / de: / reserved for future use /  / 00:05:00 /
      UTC 2013-08-05 04:00:00 :de:LazyTown - Los geht's / de: / cartoons/puppets /  / 00:25:00 /
      UTC 2013-08-05 04:25:00 :de:Der MondbÈar / de: / cartoons/puppets /  / 00:10:00 /
      UTC 2013-08-05 04:35:00 :de:Nils Holgersson / de: / cartoons/puppets /  / 00:25:00 /
      UTC 2013-08-05 05:00:00 :de:Servus Kasperl / de: / children's/youth programmes /  / 00:25:00 /
      UTC 2013-08-05 05:25:00 :de:Barbapapa / de: / cartoons/puppets /  / 00:05:00 /
      UTC 2013-08-05 05:30:00 :de:Jake und die ... / de: / cartoons/puppets /  / 00:25:00 /
      UTC 2013-08-05 05:55:00 :de:Alles okidoki / de: / children's/youth programmes /  / 00:05:00 /
      UTC 2013-08-05 06:00:00 :de:Die Pinguine aus ... / de: / cartoons/puppets /  / 00:15:00 /
      UTC 2013-08-05 06:15:00 :de:Anna und die Liebe / de: / reserved for future use /  / 00:25:00 /
      UTC 2013-08-05 06:40:00 :de:Anna und die Liebe / de: / reserved for future use /  / 00:25:00 /
      UTC 2013-08-05 07:05:00 :de:HÈor mal, wer da hÈammert! / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 07:25:00 :de:HÈor mal, wer da hÈammert! / de: / reserved for future use /  / 00:25:00 /
      UTC 2013-08-05 07:50:00 :de:Dawson's Creek / de: / reserved for future use /  / 00:45:00 /
      UTC 2013-08-05 08:35:00 :de:Der Kaufhaus-Cop / de: / comedy /  / 01:25:00 /
      UTC 2013-08-05 10:00:00 :de:Tom auf heiûer Spur / de: / children's/youth programmes /  / 00:25:00 /
      UTC 2013-08-05 10:25:00 :de:Alles okidoki / de: / children's/youth programmes /  / 00:05:00 /
      UTC 2013-08-05 10:30:00 :de:Disneys Der Fisch-Club / de: / cartoons/puppets /  / 00:25:00 /
      UTC 2013-08-05 10:55:00 :de:Scrubs - Die AnfÈanger / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 11:15:00 :de:The Middle / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 11:35:00 :de:Malcolm mittendrin / de: / reserved for future use /  / 00:25:00 /
      UTC 2013-08-05 12:00:00 :de:Malcolm mittendrin / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 12:20:00 :de:Two and a Half Men / de: / reserved for future use /  / 00:25:00 /
      UTC 2013-08-05 12:45:00 :de:How I Met Your Mother / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 13:05:00 :de:How I Met Your Mother / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 13:25:00 :de:Malcolm mittendrin / de: / reserved for future use /  / 00:25:00 /
      UTC 2013-08-05 13:50:00 :de:Malcolm mittendrin / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 14:10:00 :de:ZiB Flash / de: / news/current affairs /  / 00:05:00 /
      UTC 2013-08-05 14:15:00 :de:The Middle / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 14:35:00 :de:Scrubs - Die AnfÈanger / de: / reserved for future use /  / 00:25:00 /
      UTC 2013-08-05 15:00:00 :de:Scrubs - Die AnfÈanger / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 15:20:00 :de:Die Simpsons / de: / cartoons/puppets /  / 00:25:00 /
      UTC 2013-08-05 15:45:00 :de:Die Simpsons / de: / cartoons/puppets /  / 00:20:00 /
      UTC 2013-08-05 16:05:00 :de:ZiB Flash / de: / news/current affairs /  / 00:05:00 /
      UTC 2013-08-05 16:10:00 :de:How I Met Your Mother / de: / reserved for future use /  / 00:25:00 /
      UTC 2013-08-05 16:35:00 :de:How I Met Your Mother / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 16:55:00 :de:The Big Bang Theory / de: / reserved for future use /  / 00:20:00 /
      UTC 2013-08-05 17:15:00 :de:Two and a Half Men / de: / reserved for future use /  / 00:30:00 /
      UTC 2013-08-05 17:45:00 :de:ZiB Magazin / de: / news/current affairs /  / 00:09:00 /
      UTC 2013-08-05 17:54:00 :de:Wetter / de: / news/current affairs /  / 00:06:00 /
      UTC 2013-08-05 18:00:00 :de:ZiB 20 / de: / news/current affairs /  / 00:15:00 /
      UTC 2013-08-05 18:15:00 :de:CSI: NY / de: / reserved for future use /  / 00:50:00 /
      UTC 2013-08-05 19:05:00 :de:The Mentalist / de: / reserved for future use /  / 00:40:00 /
      UTC 2013-08-05 19:45:00 :de:ZiB Flash / de: / news/current affairs /  / 00:10:00 /
      UTC 2013-08-05 19:55:00 :de:Revenge / de: / reserved for future use /  / 00:45:00 /
      UTC 2013-08-05 20:40:00 :de:The Closer / de: / reserved for future use /  / 00:45:00 /
      UTC 2013-08-05 21:25:00 :de:Unforgettable / de: / reserved for future use /  / 00:40:00 /
      UTC 2013-08-05 22:05:00 :de:ZiB 24 / de: / news/current affairs /  / 00:20:00 /
      UTC 2013-08-05 22:25:00 :de:Defenders / de: / reserved for future use /  / 00:45:00 /
      UTC 2013-08-05 23:10:00 :de:CSI: NY / de: / reserved for future use /  / 00:40:00 /
      UTC 2013-08-05 23:50:00 :de:The Mentalist / de: / reserved for future use /  / 00:40:00 /
      I think there could be a problem with the pre-settings!
      As i did buy PrE11 only for editing this and similar videos I would be very pleased if someone could help me solve my issue.
      (Please don't tell me that I should buy Adobe Premiere Pro or any other version as them are much too expensive for my purpose and as PrE11 should be capable to do that job.)
      Best regards
