1. Re: Detecting clipping path in EPS file
drerol74 Sep 7, 2013 8:50 AM (in response to Piotr Nowicki)Hallo Piotr,
Perhaps the following approach can help.
The script places the eps (inside the selected frame) twice in a new layer: the first time with property epsImportPreferences.epsFrames = false and then with true. Afterwards the dimensions were compared and the layer deleted.
Please note that it will only work if the paths are smaller than the image dimensions.
#target InDesign
var _eps = app.selection[0].epss[0];
var _uerEPSFrames = app.epsImportPreferences.epsFrames;
var _tempLayer = app.activeDocument.layers.add();
try {
if(_eps instanceof EPS && _eps.clippingPath.photoshopPathNames.length>0) {
if(_eps.clippingPath.clippingType == ClippingPathType.NONE) {
var _savedClippingPath = __savedWithClippingPath(_eps,_tempLayer);
if(_savedClippingPath[0]) {
alert("Clipping path applied in Photoshop" + "\r\r" + "Path name: " + _savedClippingPath[1]);
} else {
alert("EPS without applied clipping path (Photoshop and InDesign)");
} else if (_eps.clippingPath.clippingType == ClippingPathType.PHOTOSHOP_PATH) {
alert("Clipping path applied in InDesign" + "\r\r" + "Path name: " + _eps.clippingPath.appliedPathName);
} catch(e) {
alert(e);
app.epsImportPreferences.epsFrames = _uerEPSFrames;
_tempLayer.remove();
function __savedWithClippingPath(_curEPS,_tempLayer) {
app.epsImportPreferences.epsFrames = false;
var _tempEPS_1 = __placeFile (_curEPS,_tempLayer);
app.epsImportPreferences.epsFrames = true;
var _tempEPS_2 = __placeFile (_curEPS,_tempLayer);
if(_tempEPS_1.geometricBounds[2] == _tempEPS_2.geometricBounds[2] && _tempEPS_1.geometricBounds[3] == _tempEPS_2.geometricBounds[3]) {
return [false,""];
} else {
_tempEPS_1.clippingPath.clippingType = ClippingPathType.PHOTOSHOP_PATH;
return [true,_tempEPS_1.clippingPath.appliedPathName];
function __placeFile (_file,_layer) {
var _filePath = _file.itemLink.filePath;
var _fileToPlace = File(_filePath);
return app.activeDocument.pages[0].place(_fileToPlace,[0,0],_layer,false)[0];
A little roundabout, i know, but i think you can not obtain the value in a direct way. But maybe someone else knows a better way.
Roland
2. Re: Detecting clipping path in EPS file
Muppet Mark Sep 7, 2013 9:33 AM (in response to drerol74)If the *.eps was created by photoshop then look to read the file. Search the photoshop scripting forum you can look for 'oclip' or the photoshop file spec tag.
