2 Replies Latest reply on Sep 6, 2013 9:17 AM by James A Hiltz CET
    multiple if else statement
    James A Hiltz CET Level 1
      Ok I know I have a conflict with the blank field statment however I need to have the pass statment to be grater than or equal to as indicated.
      the pass fail statment work but I can not get the blank field to work.
      Any input is greatly appreaciated.
      // Get the field values, as numbers
      var dr1 = +getField("DD_P_Required_3").value;
      var do1 = +getField("Obtained_P_3").value;
      var wd1 = +getField("WD_3").value;
      // If wd1 is blank or zero, set this field to a single space
      if(wd1 = 0) {
          event.value = "";  // Blank this field
      // If do1 is grater than or equal to dr1, set this field to pass
      if (do1 >= dr1) {
          event.value = "Pass";
      // If do1 is less than dr1, set this field to fail
      if (do1 < dr1) {
          event.value = "Fail";
