6 Replies Latest reply on Sep 9, 2013 9:05 AM by ratsurfer1
    How can I batch turn on/turn off layers in a large group of files
    ratsurfer1
      I lifted this code from another discussion that purports to say it works, but it doesn't.
      I keep getting the Error: Object does not support the property or method 'length'
      I've looked at other batch process scripts that that line of code seems to be correct.
      I know this is a very simple script, and that the turn on/turn off layer part of the script works perfectly fine (on individuall pages), but for some reason I can't get it to batch process.
      I have a multi-version set of files with layers such as "de" for germany, "us" for United States, etc. that I need to batch turn on so that I can print.
      Here is what I have:
      var myFolder = Folder.selectDialog("Select Indesign Folder");
      var myIndsnFiles = myFolder.getFiles("*.indd");
      for(k=0; k<myIndsnFiles.length; k++)
         var myIndsnFiles = app.open(myIndsnFiles[k]);
      var myIndsnFiles = app.documents[0];
      var answersLayer = myIndsnFiles.layers.item("us");
      answersLayer.visible = false;
          app.activeDocument.close(SaveOptions.yes);
      Can you fix/explain what I'm doing wrong?
        • 2. Re: How can I batch turn on/turn off layers in a large group of files
          RobertKyle Level 2
          Without testing anything, I'd guess that it's not a good idea to keep reusing the variable name "myIndsnFiles." First it's an array of files in a folder, then it becomes a reference to a document. So on the second pass through your loop, javascript is trying to get the length of the document instead of the array.
          • 3. Re: How can I batch turn on/turn off layers in a large group of files
            Sergey Anosov Level 1
            Hi!
            Try this version, I hope it will do:
            if( myFolder != null )
                for( var k = myIndsnFiles.length -1; k >= 0; k--)
                    try
                        var myIndsnDoc = app.open(myIndsnFiles[k]);
                        var answersLayer = myIndsnDoc.layers.item("us");
                        myIndsnDoc.close(SaveOptions.yes);
                    } catch ( error ) {};// try-catch
                };// for
            };// if
            • 4. Re: How can I batch turn on/turn off layers in a large group of files
              Jump_Over Level 5
              If we talk about mistakes:
              This var - myIndsnFiles is assigned 3 times but your code is iterating through 1st version, so fails in 2nd step. Use different var names or Sergey's code.
              Jarek
              • 5. Re: How can I batch turn on/turn off layers in a large group of files
                @ratsurfer1 – you are missing one crucial point from the other discussion you are mentioning:
                The first thing you have to do is setting the user interaction level of the app temporarily to "never interact".
                app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
                //Then insert your lines of code here…
                //After running the script restore it back:
                app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
                And it would be best to improve the catch(e){}-scenario with an error message.
                Something like that (or a more elaborate one):
                catch(e){alert(e.message)};
                Uwe
                • 6. Re: How can I batch turn on/turn off layers in a large group of files
                  ratsurfer1 Level 1
                  I got Sergey's Version to work. See below. It's very different than my original. I understood why my original wasn't working, but couldn't figure out how to fix it. I tried inserting Laubender's code into this, but I got the same error as above "Object does not support the property or method 'length'".
                  I made some adjustments so that the script turns off all layers that should be off, then turns on the layer I need.
                  Everything runs perfect except I wonder if there's a way I can turn off any warnings, such as missing links, so that it processes the whole batch without pausing. Maybe that's what Laubender was referring to.
                          try
                              var myDoc = app.open(myIndsnFiles[k]);
                  var inLayer = myDoc.layers.item("in");
                  inLayer.visible = false;
                  var itLayer = myDoc.layers.item("it");
                  itLayer.visible = false;
                  var deLayer = myDoc.layers.item("de");
                  deLayer.visible = false;
                  var ukLayer = myDoc.layers.item("uk");
                  ukLayer.visible = false;
                  var usLayer = myDoc.layers.item("us");
                  usLayer.visible = false;
                  var intLayer = myDoc.layers.item("INT");
                  intLayer.visible = false;
                  deLayer.visible = true;
                              myDoc.close(SaveOptions.yes);
                      };// for
                  };// if
