20 Replies Latest reply: Sep 9, 2013 10:40 AM by kglad RSS
    Problem with events and Movieclips
    vari25 Community Member
      Hi All.
      I have myself in a situation where everything was perfect with mouse click and drag, keyboard events and zoom events.
      The project is:
      A movieclip with images sequence: For Original background.
      And other movieclips: aslo images sequence (Pngs)
      They were all given separate mouse events and zoom and key events.
      Now wen I click the button with concerned movieclip to function, only the png image seuence is rotating and the main mc is not.
      What should I do to rotate both the activated whichever png mcs and main mc also with these.
      Please help.
      Thank you in advance.
        • 1. Re: Problem with events and Movieclips
          kglad CommunityMVP
          what code executes when that button is clicked?
          • 2. Re: Problem with events and Movieclips
            I have this for every button and a mouse event and key event and zoom event added.
            Below is the button function:
            garage_horizon_btn.addEventListener(MouseEvent.CLICK,garage)
            function garage(event:MouseEvent):void
            garage_horizon_mc.gotoAndStop(rotationframe);
            garage_horizon_mc.visible=true;
            garage_horizon_mc.stop();
            garage_moss_mc.visible=false;
            garage_ocean_mc.visible=false;
            gutter_ocean_mc.visible=false;
            gutter_horizon_mc.visible=false;
            gutter_moss_mc.visible=false;
            main_mc.visible=false;
            Mouseevent:
            var rotater_gah:MovieClip = garage_horizon_mc;
            var offsetFrame_gah:int = rotater_gah.currentFrame;
            var offsetX_gah:Number = 0;
            var percent_gah:Number = 0;
            rotater_gah.addEventListener(MouseEvent.MOUSE_DOWN,startDragging_gah);
            rotater_gah.addEventListener(MouseEvent.MOUSE_UP,stopDragging_gah);
            function startDragging_gah(e:MouseEvent):void
            rotater_gah.addEventListener(MouseEvent.MOUSE_MOVE,drag_gah);
            offsetX_gah = e.target.mouseX;
            function stopDragging_gah(e:MouseEvent):void
            rotater_gah.removeEventListener(MouseEvent.MOUSE_MOVE,drag_gah);
            offsetFrame_gah = rotater_gah.currentFrame;
            function drag_gah(e:MouseEvent):void
            percent_gah = (e.target.mouseX - offsetX_gah)/rotater_gah.width;
            var frame_gah:int = Math.round(percent_gah*rotater_gah.totalFrames) + offsetFrame_gah +1;
            while (frame_gah>rotater_gah.totalFrames)
              frame_gah -=  rotater_gah.totalFrames;
            while (frame_gah<=0)
              frame_gah +=  rotater_gah.totalFrames;
            rotater_gah.gotoAndStop(frame_gah);
            rotationframe  =  garage_horizon_mc.currentFrame;
            I want this mouse event for every movieclip so added separately for all mcs. the problem is this being a png could be able to trigger the main_mc being static wen clicked this button.
            What to do??
            Or otherwise can I add the mouse event and keyboard event to the stage itself making it common for all movieclips which are image seuences???
            Please help..
            • 3. Re: Problem with events and Movieclips
              I have different vaiables assigned to eah mc's mouse event. So can I use The these multiple mouse events simultaneously atleast.
              Is there any possiblity of that sort??
              Please help..
              • 4. Re: Problem with events and Movieclips
                kglad CommunityMVP
                i'm not sure i understand you .
                i understand the code you posted.  and i think i understand that you want to apply the code below Mouseevent to some other objects but those objects are png's, not movieclips.  is that correct?
                if so, convert the png's to movieclips (right click the png on stage>click convert to symbol>movieclip>ok).
                • 5. Re: Problem with events and Movieclips
                  I have movieclips of images sequences(pngs).
                  The code posted above is what I used for mouse event for the movieclip which is made visible by the button.
                  This code I have for every movieclip. That is as flash does not accept same variable, so changed the variable name and used the code for every mc.
                  Now  the main mc ie (the whole house). And other movieclips are parts of it as in garage etc. in png's.
                  As I told u, I have this situation where if I click on garage button, then only the mouse event for garage in functioning.
                  wen i want the main_mc the background also to move with the garage.
                  I hope I have presented clearly.
                  Thank u.
                  Any help please
                  • 6. Re: Problem with events and Movieclips
                    kglad CommunityMVP
                    if you want that code to apply to a group of two (or more) movieclips, reparent them and apply that code to the parent:
                    var p:MovieClip=new MovieClip();
                    addChild(p);
                    p.addChild(main_mc);
                    p.addChild(garage_horizon_mc);
                    var rotater_gah:MovieClip=p;
                    etc
                    or, if you want to apply that code to more than one movieclip concurrently, but not as a group, add that rotater_gah code to a function body and call that function sequentially.
                    whateverF(main_mc);
                    whateverF(garage_horizon_mc);
                    function whateverF(rotater_gah:MovieClip):void{
                    etc
                    • 7. Re: Problem with events and Movieclips
                      Thank u for the reply but it has not solved my problem.
                      The first solution was not triggering the function.
                      My movieclips are in timeline in separate layers.
                      The second one was calling the function, but the same problem.
                      Yes, I want to work these in groups only.
                      Please help..
                      • 8. Re: Problem with events and Movieclips
                        kglad CommunityMVP
                        copy and paste the code you tried.  there's no need to try them both.  just use the one that does what you want.
                        • 9. Re: Problem with events and Movieclips
                              images_mc.garage_horizon_mc.visible=true;
                              images_mc.garage_horizon_mc.stop();
                              images_mc.garage_moss_mc.visible=false;
                              images_mc.garage_ocean_mc.visible=false;
                          garage_moss_btn.addEventListener(MouseEvent.CLICK,garage1)
                          function garage1(event:MouseEvent):void
                              images_mc.garage_moss_mc.visible=true;
                              images_mc.garage_moss_mc.stop();
                              images_mc.garage_horizon_mc.visible=false;
                          images_mc.main_mc.stop();
                          rot(images_mc.main_mc);
                          rot(images_mc.garage_horizon_mc);
                          rot(images_mc.garage_moss_mc);
                          function rot(rotater:MovieClip):void
                          var offsetFrame:int = rotater.currentFrame;
                          var offsetX:Number = 0;
                          var percent:Number = 0;
                          rotater.addEventListener(MouseEvent.MOUSE_DOWN,startDragging);
                          rotater.addEventListener(MouseEvent.MOUSE_UP,stopDragging);
                          function startDragging(e:MouseEvent):void
                              rotater.addEventListener(MouseEvent.MOUSE_MOVE,drag);
                              offsetX = e.target.mouseX;
                          function stopDragging(e:MouseEvent):void
                              rotater.removeEventListener(MouseEvent.MOUSE_MOVE,drag);
                              offsetFrame = rotater.currentFrame;
                          function drag(e:MouseEvent):void
                              percent = (e.target.mouseX - offsetX)/rotater.width;
                              var frame:int = Math.round(percent*rotater.totalFrames) + offsetFrame +1;
                              while (frame>rotater.totalFrames)
                                  frame -=  rotater.totalFrames;
                              while (frame<=0)
                                  frame +=  rotater.totalFrames;
                              rotater.gotoAndStop(frame);
                          • 10. Re: Problem with events and Movieclips
                            kglad CommunityMVP
                            use:
                            var mcA:Array = [garage_horizon_mc,garage_moss_mc,garage_ocean_mc,gutter_ocean_mc,gutter_horizon_mc,gutte r_moss_mc,main_mc];
                            for(var i:int=0;i<mcA.length;i++){
                                mcA[i].addEventListener(MouseEvent.CLICK,garageF);
                            function garageF(e:MouseEvent):void{
                                    mcA[i].visible = false;
                                var mc:MovieClip = MovieClip(e.currentTarget);
                                mc.visible = true;
                                whateverF(mc);
                            rotater_gah.offsetFrame_gah = rotater_gah.currentFrame;
                            rotater_gah.offsetX_gah = 0;
                            rotater_gah.percent_gah = 0;
                            function startDragging_gah(e:MouseEvent):void {
                                e.currentTarget.addEventListener(MouseEvent.MOUSE_MOVE,drag_gah);
                                e.currentTarget.offsetX_gah = e.target.mouseX;
                            function stopDragging_gah(e:MouseEvent):void {
                                e.currentTarget.removeEventListener(MouseEvent.MOUSE_MOVE,drag_gah);
                                e.currentTarget.offsetFrame_gah = rotater_gah.currentFrame;
                            function drag_gah(e:MouseEvent):void {
                                e.currentTarget.percent_gah = (e.target.mouseX - e.currentTarget.offsetX_gah)/e.currentTarget.width;
                                var frame_gah:int = Math.round(e.currentTarget.percent_gah*e.currentTarget.totalFrames) + e.currentTarget.offsetFrame_gah +1;
                                while (frame_gah>e.currentTarget.totalFrames) {
                                    frame_gah -=  e.currentTarget.totalFrames;
                                while (frame_gah<=0) {
                                    frame_gah +=  e.currentTarget.totalFrames;
                                e.currentTarget.gotoAndStop(frame_gah);
                            • 11. Re: Problem with events and Movieclips
                              Thank u so much.
                              But there is an error, while compiling.
                              Scene 1, Layer 'actions', Frame 1, Line 1311120: Access of undefined property rotater_gah.
                              Line 131: e.currentTarget.offsetFrame_gah = rotater_gah.currentFrame;
                              What could I have done wrong??
                              Please help.
                              Thank u
                              • 12. Re: Problem with events and Movieclips
                                kglad CommunityMVP
                                my error.  that should be:
                                e.currrentTarget.offsetFrame_gah = e.currentTarget.currentFrame;
                                • 13. Re: Problem with events and Movieclips
                                  Thank u again.
                                  Sorry, but again I need help because the problem exists.
                                  now whatever I am clicking it is functioning and rotating.
                                  The  problem is,
                                  For example; the garage_horizon_mc is a png sequence right?
                                  now wen i am clicking the options (eg:garage_Horizon_mc), the background i.e. main_mc is hiding. actually i want the main also  to be rotating with the options i enable.
                                  is it possible?
                                  Hope i am clear.
                                  Thank u so much once again.
                                  • 14. Re: Problem with events and Movieclips
                                    kglad CommunityMVP
                                    again, if you want to group objects so the rotate etc together, reparent them to a common parent.
                                    or, if you want to use the current approach but not have all the movieclips (like main_mc) be clickable, remove them from mcA.
                                    • 15. Re: Problem with events and Movieclips
                                      Sorry, I am so confused because its way beyond my knowledge.
                                      Could u please explain.
                                      Reparent them .....
                                      addChild(p);
                                      Is this what u were suggesting??
                                      Please help.
                                      • 16. Re: Problem with events and Movieclips
                                        kglad CommunityMVP
                                        yes.
                                        • 17. Re: Problem with events and Movieclips
                                          Thank u.
                                          But its not rotating now.
                                          Any suggestions??
                                          Please help.
                                          • 18. Re: Problem with events and Movieclips
                                            kglad CommunityMVP
                                            again, show the complete code you're using and explain what's not rotating.
                                            • 19. Re: Problem with events and Movieclips
                                              Thank U so much.
                                              I have added a target to rotate with same keyframe numbers.
                                              It has successfully been solved.
                                              Thank u again.
                                              • 20. Re: Problem with events and Movieclips
                                                kglad CommunityMVP
                                                you're welcome.
