1 Reply Latest reply on Sep 7, 2013 9:25 AM by Jim_Simon
    Output file is much larger than trimmed input file
    fooglestiltskin
      I am relatively new user of Premier Pro CC (on a Mac Mini).
      My (simple) task is to trim a 749.6MB .m2ts. The details from MediaInfo are towards the bottom of the post.
      I set up a single sequence as AVCHD, 1920x1080, square pixels, 16:9, 25 fps, 48kHz audio.
      I brought in the m2ts file and trimmed off a couple of minutes from the start and end.
      I then exported the Media twice:
      1) "Match Sequence Settings", resulted in a 2.95GB .mpeg file.
      2) (after reading an article here) H.264 Blu-Ray, Multiplexer TS, resulted in 3.46GB file.
      Given then all I want is pretty much the same file coming out, but with some bits trimmed off the front and back (future ones will be several of these snippets edited together), in the same format in which it was recorded.
      It was recorded from an Hauppage PVR HD.
      Your guidance on what settings to use for the sequence and the export and any other relevant settings would be greatly appreciated.
      Malcolm
      MediaInfo output:
      General
      Complete name                            : MyFile.m2ts
      Format                                   : MPEG-TS
      File size                                : 715 MiB
      Duration                                 : 15mn 30s
      Overall bit rate mode                    : Variable
      Overall bit rate                         : 6 443 Kbps
      Maximum Overall bit rate                 : 18.0 Mbps
      Video
      Menu ID                                  : 1 (0x1)
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format profile                           : Main@L4.0
      Format settings, CABAC                   : Yes
      Format settings, ReFrames                : 4 frames
      Format settings, GOP                     : M=4, N=32
      Codec ID                                 : 27
      Duration                                 : 15mn 30s
      Bit rate mode                            : Variable
      Bit rate                                 : 5 736 Kbps
      Maximum bit rate                         : 20.0 Mbps
      Width                                    : 1 920 pixels
      Height                                   : 1 080 pixels
      Display aspect ratio                     : 16:9
      Frame rate                               : 25.000 fps
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Interlaced
      Scan order                               : Top Field First
      Bits/(Pixel*Frame)                       : 0.111
      Stream size                              : 637 MiB (89%)
      Color primaries                          : BT.709
      Transfer characteristics                 : BT.709
      Matrix coefficients                      : BT.709
      Audio
      Menu ID                                  : 1 (0x1)
      Format                                   : AC-3
      Format/Info                              : Audio Coding 3
      Mode extension                           : CM (complete main)
      Format settings, Endianness              : Big
      Codec ID                                 : 129
      Duration                                 : 15mn 30s
      Bit rate mode                            : Constant
      Bit rate                                 : 384 Kbps
      Channel(s)                               : 2 channels
      Channel positions                        : Front: L R
      Sampling rate                            : 48.0 KHz
      Bit depth                                : 16 bits
      Compression mode                         : Lossy
      Stream size                              : 42.6 MiB (6%)
