2 Replies Latest reply on Sep 7, 2013 10:44 PM by danielocdh
    How to correctly import x264 videos?
    danielocdh
      I'm trying to import some videos, but I get a problem, the video duration gets detected correctly but the video plays at 2x speed, so for example if I play a video of 10 seconds, only the first 5 seconds play at 2x speed, then I only see the last frame for the remaining 5 seconds.
      This happens on the clip preview and also on the sequence preview when I add the clip to a sequence.
      This happens with LAV decoder.
      Other things I tried is reading the video with ffdshow libavcodec and x264vfw, but I get random frames inserted during all the video, only LAV decoder renders video correctly but at 2x speed.
      The videos are contained in avi files without audio they play correctly with ffdshow, LAV decoder and x264vfw on media player classic home cinema.
      I also tried with same results openning them with virtualdub and just save them without recoding (as this has solved many problems for me in the past)
      Any idea or suggestion will be appreciated
      Here is the MediaInfo for one of my files:
      General
      Complete name                            : U:\Movie34.avi
      Format                                   : AVI
      Format/Info                              : Audio Video Interleave
      File size                                : 24.6 MiB
      Duration                                 : 58s 133ms
      Overall bit rate                         : 3 547 Kbps
      Video
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format profile                           : High@L4.0
      Format settings, CABAC                   : Yes
      Format settings, ReFrames                : 2 frames
      Codec ID                                 : H264
      Bit rate                                 : 3 540 Kbps
      Width                                    : 1 240 pixels
      Height                                   : 1 044 pixels
      Display aspect ratio                     : 1.188
      Frame rate                               : 30.000 fps
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Progressive
      Bits/(Pixel*Frame)                       : 0.091
      Stream size                              : 24.5 MiB (100%)
      Writing library                          : x264 core 130 r2274bm c832fe9
      Encoding settings                        : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=6 / sliced_threads=1 / slices=6 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=2 / ip_ratio=1.40 / aq=0
