11 Replies Latest reply on Sep 24, 2013 3:57 AM by saumishr
      • 1. Re: Virtual Host (localhost) + Wamp 2.1
        saumishr Employee Moderator
        Could you please be more specific about the issue which you are facing.
        Is the Chrome extension icon is gray? If yes, that means that either the Edge Inspect desktop application isn't running or that the Chrome extension is unable to contact it. I'll have to ask some basic questions here:
        1. Have you started the Edge Inspect desktop application?
        2. Do you see any error messages when you try to start the desktop application?
        3. The Edge Inspect icon should appear in your system tray, do you see it there?
        4. Are you looged in with Adobe ID in Edge inspect desktop app?
        • 2. Re: Virtual Host (localhost) + Wamp 2.1
          Sytou34fr Level 1
            1. Yes
            1. No
            1. Yes
            1. Yes
          The connection between the PC and the tablet is done correctly. When I browse with Chrome on websites (Google, PayPal, Yahoo), the contents of the Chrome browser on the PC appears on the tablet without a problem. The firewall on my PC is configured to pass the request from the tablet. This is a problem specific to the use of localhost WAMP server running on my PC ? A bug?
          Thank you for your help.PS : I have atttached a screenshot (192.168.1.98 is the IP address of my PC. The name of my PC is Danemark).
          device_model = MPMAN MPDC99 BT IPS
          device_res = 1024x720
          orientation = landscape
          os_name = Android
          os_version = 4.1.1
          pixel_density = 160 dpi
          request_id = 1d4ce08b-20f5-4a21-81ea-d7e7dbcdf3c5
          status = Viewport
          url = http://192.168.1.98/midivin/index.php?main_page=index&manufacturers_id=45
          Ce message a été modifié par: Sytou34fr
          • 3. Re: Virtual Host (localhost) + Wamp 2.1
            Thanks for the information!
            You need to reconfigure the server to allow connections from other machines. For instance if you have a wamp server running locally you need to modify bin\apache\Apache2.4.4\httpd.conf. Find this: Allow from 127.0.0.1 and Change them to read: Allow from All . By default httpd conf only allows connections from localhost.
            • 4. Re: Virtual Host (localhost) + Wamp 2.1
              Sytou34fr Level 1
              No change
              File httpd.conf :
              # This is the main Apache HTTP server configuration file.  It contains the
              # configuration directives that give the server its instructions.
              # See <URL:http://httpd.apache.org/docs/2.2> for detailed information.
              # In particular, see
              # <URL:http://httpd.apache.org/docs/2.2/mod/directives.html>
              # for a discussion of each configuration directive.
              # Do NOT simply read the instructions in here without understanding
              # what they do.  They're here only as hints or reminders.  If you are unsure
              # consult the online docs. You have been warned.
              # Configuration and logfile names: If the filenames you specify for many
              # of the server's control files begin with "/" (or "drive:/" for Win32), the
              # server will use that explicit path.  If the filenames do *not* begin
              # with "/", the value of ServerRoot is prepended -- so "logs/foo.log"
              # with ServerRoot set to "C:/Program Files/Apache Software Foundation/Apache2.2" will be interpreted by the
              # server as "C:/Program Files/Apache Software Foundation/Apache2.2/logs/foo.log".
              # NOTE: Where filenames are specified, you must use forward slashes
              # instead of backslashes (e.g., "c:/apache" instead of "c:\apache").
              # If a drive letter is omitted, the drive on which Apache.exe is located
              # will be used by default.  It is recommended that you always supply
              # an explicit drive letter in absolute paths to avoid confusion.
              # ServerRoot: The top of the directory tree under which the server's
              # configuration, error, and log files are kept.
              # Do not add a slash at the end of the directory path.  If you point
              # ServerRoot at a non-local disk, be sure to point the LockFile directive
              # at a local disk.  If you wish to share the same ServerRoot for multiple
              # httpd daemons, you will need to change at least LockFile and PidFile.
              ServerRoot "c:/wamp/bin/apache/apache2.2.17"
              # Listen: Allows you to bind Apache to specific IP addresses and/or
              # ports, instead of the default. See also the <VirtualHost>
              # directive.
              # Change this to Listen on specific IP addresses as shown below to
              # prevent Apache from glomming onto all bound IP addresses.
              #Listen 12.34.56.78:80
              Listen 80
              # Dynamic Shared Object (DSO) Support
              # To be able to use the functionality of a module which was built as a DSO you
              # have to place corresponding `LoadModule' lines at this location so the
              # directives contained in it are actually available _before_ they are used.
              # Statically compiled modules (those listed by `httpd -l') do not need
              # to be loaded here.
              # Example:
              # LoadModule foo_module modules/mod_foo.so
              LoadModule actions_module modules/mod_actions.so
              LoadModule alias_module modules/mod_alias.so
              LoadModule asis_module modules/mod_asis.so
              LoadModule auth_basic_module modules/mod_auth_basic.so
              #LoadModule auth_digest_module modules/mod_auth_digest.so
              #LoadModule authn_alias_module modules/mod_authn_alias.so
              #LoadModule authn_anon_module modules/mod_authn_anon.so
              #LoadModule authn_dbd_module modules/mod_authn_dbd.so
              #LoadModule authn_dbm_module modules/mod_authn_dbm.so
              LoadModule authn_default_module modules/mod_authn_default.so
              LoadModule authn_file_module modules/mod_authn_file.so
              #LoadModule authnz_ldap_module modules/mod_authnz_ldap.so
              #LoadModule authz_dbm_module modules/mod_authz_dbm.so
              LoadModule authz_default_module modules/mod_authz_default.so
              LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
              LoadModule authz_host_module modules/mod_authz_host.so
              #LoadModule authz_owner_module modules/mod_authz_owner.so
              LoadModule authz_user_module modules/mod_authz_user.so
              LoadModule autoindex_module modules/mod_autoindex.so
              #LoadModule cache_module modules/mod_cache.so
              #LoadModule cern_meta_module modules/mod_cern_meta.so
              LoadModule cgi_module modules/mod_cgi.so
              #LoadModule charset_lite_module modules/mod_charset_lite.so
              #LoadModule dav_module modules/mod_dav.so
              #LoadModule dav_fs_module modules/mod_dav_fs.so
              #LoadModule dav_lock_module modules/mod_dav_lock.so
              #LoadModule dbd_module modules/mod_dbd.so
              #LoadModule deflate_module modules/mod_deflate.so
              LoadModule dir_module modules/mod_dir.so
              #LoadModule disk_cache_module modules/mod_disk_cache.so
              #LoadModule dumpio_module modules/mod_dumpio.so
              LoadModule env_module modules/mod_env.so
              #LoadModule expires_module modules/mod_expires.so
              #LoadModule ext_filter_module modules/mod_ext_filter.so
              #LoadModule file_cache_module modules/mod_file_cache.so
              #LoadModule filter_module modules/mod_filter.so
              #LoadModule headers_module modules/mod_headers.so
              #LoadModule ident_module modules/mod_ident.so
              #LoadModule imagemap_module modules/mod_imagemap.so
              LoadModule include_module modules/mod_include.so
              #LoadModule info_module modules/mod_info.so
              LoadModule isapi_module modules/mod_isapi.so
              #LoadModule ldap_module modules/mod_ldap.so
              #LoadModule logio_module modules/mod_logio.so
              LoadModule log_config_module modules/mod_log_config.so
              #LoadModule log_forensic_module modules/mod_log_forensic.so
              #LoadModule mem_cache_module modules/mod_mem_cache.so
              LoadModule mime_module modules/mod_mime.so
              #LoadModule mime_magic_module modules/mod_mime_magic.so
              LoadModule negotiation_module modules/mod_negotiation.so
              #LoadModule proxy_module modules/mod_proxy.so
              #LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
              #LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
              #LoadModule proxy_connect_module modules/mod_proxy_connect.so
              #LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
              #LoadModule proxy_http_module modules/mod_proxy_http.so
              LoadModule rewrite_module modules/mod_rewrite.so
              LoadModule setenvif_module modules/mod_setenvif.so
              #LoadModule speling_module modules/mod_speling.so
              #LoadModule ssl_module modules/mod_ssl.so
              #LoadModule status_module modules/mod_status.so
              #LoadModule substitute_module modules/mod_substitute.so
              #LoadModule unique_id_module modules/mod_unique_id.so
              #LoadModule userdir_module modules/mod_userdir.so
              #LoadModule usertrack_module modules/mod_usertrack.so
              #LoadModule version_module modules/mod_version.so
              LoadModule vhost_alias_module modules/mod_vhost_alias.so
              LoadModule php5_module "c:/wamp/bin/php/php5.3.5/php5apache2_2.dll"
              <IfModule !mpm_netware_module>
              <IfModule !mpm_winnt_module>
              # If you wish httpd to run as a different user or group, you must run
              # httpd as root initially and it will switch.
              # User/Group: The name (or #number) of the user/group to run httpd as.
              # It is usually good practice to create a dedicated user and group for
              # running httpd, as with most system services.
              User daemon
              Group daemon
              </IfModule>
              </IfModule>
              # 'Main' server configuration
              # The directives in this section set up the values used by the 'main'
              # server, which responds to any requests that aren't handled by a
              # <VirtualHost> definition.  These values also provide defaults for
              # any <VirtualHost> containers you may define later in the file.
              # All of these directives may appear inside <VirtualHost> containers,
              # in which case these default settings will be overridden for the
              # virtual host being defined.
              # ServerAdmin: Your address, where problems with the server should be
              # e-mailed.  This address appears on some server-generated pages, such
              # as error documents.  e.g. admin@your-domain.com
              ServerAdmin admin@localhost
              # ServerName gives the name and port that the server uses to identify itself.
              # This can often be determined automatically, but we recommend you specify
              # it explicitly to prevent problems during startup.
              # If your host doesn't have a registered DNS name, enter its IP address here.
              ServerName localhost:80
              # DocumentRoot: The directory out of which you will serve your
              # documents. By default, all requests are taken from this directory, but
              # symbolic links and aliases may be used to point to other locations.
              DocumentRoot "c:/wamp/www/"
              # Each directory to which Apache has access can be configured with respect
              # to which services and features are allowed and/or disabled in that
              # directory (and its subdirectories).
              # First, we configure the "default" to be a very restrictive set of
              # features.
              <Directory />
                  Options FollowSymLinks
                  AllowOverride None
                  Order deny,allow
                  Deny from all
              </Directory>
              # Note that from this point forward you must specifically allow
              # particular features to be enabled - so if something's not working as
              # you might expect, make sure that you have specifically enabled it
              # below.
              # This should be changed to whatever you set DocumentRoot to.
              <Directory "c:/wamp/www/">
                  # Possible values for the Options directive are "None", "All",
                  # or any combination of:
                  #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
                  # Note that "MultiViews" must be named *explicitly* --- "Options All"
                  # doesn't give it to you.
                  # The Options directive is both complicated and important.  Please see
                  # http://httpd.apache.org/docs/2.2/mod/core.html#options
                  # for more information.
                  Options Indexes FollowSymLinks
                  # AllowOverride controls what directives may be placed in .htaccess files.
                  # It can be "All", "None", or any combination of the keywords:
                  #   Options FileInfo AuthConfig Limit
                  AllowOverride all
                  # Controls who can get stuff from this server.
              #   onlineoffline tag - don't remove
                  Order Deny,Allow
                  Deny from all
                  Allow from all
              </Directory>
              # DirectoryIndex: sets the file that Apache will serve if a directory
              # is requested.
              <IfModule dir_module>
                  DirectoryIndex index.php index.php3 index.html index.htm
              </IfModule>
              # The following lines prevent .htaccess and .htpasswd files from being
              # viewed by Web clients.
              <FilesMatch "^\.ht">
                  Order allow,deny
                  Deny from all
                  Satisfy All
              </FilesMatch>
              # ErrorLog: The location of the error log file.
              # If you do not specify an ErrorLog directive within a <VirtualHost>
              # container, error messages relating to that virtual host will be
              # logged here.  If you *do* define an error logfile for a <VirtualHost>
              # container, that host's errors will be logged there and not here.
              ErrorLog "c:/wamp/logs/apache_error.log"
              # LogLevel: Control the number of messages logged to the error_log.
              # Possible values include: debug, info, notice, warn, error, crit,
              # alert, emerg.
              LogLevel warn
              <IfModule log_config_module>
                  # The following directives define some format nicknames for use with
                  # a CustomLog directive (see below).
                  LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
                  LogFormat "%h %l %u %t \"%r\" %>s %b" common
                  <IfModule logio_module>
                    # You need to enable mod_logio.c to use %I and %O
                    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
                  </IfModule>
                  # The location and format of the access logfile (Common Logfile Format).
                  # If you do not define any access logfiles within a <VirtualHost>
                  # container, they will be logged here.  Contrariwise, if you *do*
                  # define per-<VirtualHost> access logfiles, transactions will be
                  # logged therein and *not* in this file.
                  CustomLog "c:/wamp/logs/access.log" common
                  # If you prefer a logfile with access, agent, and referer information
                  # (Combined Logfile Format) you can use the following directive.
                  #CustomLog "logs/access.log" combined
              </IfModule>
              <IfModule alias_module>
                  # Redirect: Allows you to tell clients about documents that used to
                  # exist in your server's namespace, but do not anymore. The client
                  # will make a new request for the document at its new location.
                  # Example:
                  # Redirect permanent /foo http://localhost/bar
                  # Alias: Maps web paths into filesystem paths and is used to
                  # access content that does not live under the DocumentRoot.
                  # Example:
                  # Alias /webpath /full/filesystem/path
                  # If you include a trailing / on /webpath then the server will
                  # require it to be present in the URL.  You will also likely
                  # need to provide a <Directory> section to allow access to
                  # the filesystem path.
                  # ScriptAlias: This controls which directories contain server scripts.
                  # ScriptAliases are essentially the same as Aliases, except that
                  # documents in the target directory are treated as applications and
                  # run by the server when requested rather than as documents sent to the
                  # client.  The same rules about trailing "/" apply to ScriptAlias
                  # directives as to Alias.
                  ScriptAlias /cgi-bin/ "cgi-bin/"
              </IfModule>
              <IfModule cgid_module>
                  # ScriptSock: On threaded servers, designate the path to the UNIX
                  # socket used to communicate with the CGI daemon of mod_cgid.
                  #Scriptsock logs/cgisock
              </IfModule>
              # "C:/Program Files/Apache Software Foundation/Apache2.2/cgi-bin" should be changed to whatever your ScriptAliased
              # CGI directory exists, if you have that configured.
              <Directory "cgi-bin">
                  AllowOverride None
                  Options None
                  Order allow,deny
                  Allow from all
              </Directory>
              # DefaultType: the default MIME type the server will use for a document
              # if it cannot otherwise determine one, such as from filename extensions.
              # If your server contains mostly text or HTML documents, "text/plain" is
              # a good value.  If most of your content is binary, such as applications
              # or images, you may want to use "application/octet-stream" instead to
              # keep browsers from trying to display binary files as though they are
              # text.
              DefaultType text/plain
              <IfModule mime_module>
                  # TypesConfig points to the file containing the list of mappings from
                  # filename extension to MIME-type.
                  TypesConfig conf/mime.types
                  # AddType allows you to add to or override the MIME configuration
                  # file specified in TypesConfig for specific file types.
                  #AddType application/x-gzip .tgz
                  # AddEncoding allows you to have certain browsers uncompress
                  # information on the fly. Note: Not all browsers support this.
                  #AddEncoding x-compress .Z
                  #AddEncoding x-gzip .gz .tgz
                  # If the AddEncoding directives above are commented-out, then you
                  # probably should define those extensions to indicate media types:
                  AddType application/x-compress .Z
                  AddType application/x-gzip .gz .tgz
                  AddType application/x-httpd-php .php
                  AddType application/x-httpd-php .php3
                  # AddHandler allows you to map certain file extensions to "handlers":
                  # actions unrelated to filetype. These can be either built into the server
                  # or added with the Action directive (see below)
                  # To use CGI scripts outside of ScriptAliased directories:
                  # (You will also need to add "ExecCGI" to the "Options" directive.)
                  #AddHandler cgi-script .cgi
                  # For type maps (negotiated resources):
                  #AddHandler type-map var
                  # Filters allow you to process content before it is sent to the client.
                  # To parse .shtml files for server-side includes (SSI):
                  # (You will also need to add "Includes" to the "Options" directive.)
                  #AddType text/html .shtml
                  #AddOutputFilter INCLUDES .shtml
              </IfModule>
              # The mod_mime_magic module allows the server to use various hints from the
              # contents of the file itself to determine its type.  The MIMEMagicFile
              # directive tells the module where the hint definitions are located.
              #MIMEMagicFile conf/magic
              # Customizable error responses come in three flavors:
              # 1) plain text 2) local redirects 3) external redirects
              # Some examples:
              #ErrorDocument 500 "The server made a boo boo."
              #ErrorDocument 404 /missing.html
              #ErrorDocument 404 "/cgi-bin/missing_handler.pl"
              #ErrorDocument 402 http://localhost/subscription_info.html
              # EnableMMAP and EnableSendfile: On systems that support it,
              # memory-mapping or the sendfile syscall is used to deliver
              # files.  This usually improves server performance, but must
              # be turned off when serving from networked-mounted
              # filesystems or if support for these functions is otherwise
              # broken on your system.
              #EnableMMAP off
              #EnableSendfile off
              # Supplemental configuration
              # The configuration files in the conf/extra/ directory can be
              # included to add extra features or to modify the default configuration of
              # the server, or you may simply copy their contents here and change as
              # necessary.
              # Server-pool management (MPM specific)
              #Include conf/extra/httpd-mpm.conf
              # Multi-language error messages
              #Include conf/extra/httpd-multilang-errordoc.conf
              # Fancy directory listings
              #Include conf/extra/httpd-autoindex.conf
              # Language settings
              #Include conf/extra/httpd-languages.conf
              # User home directories
              #Include conf/extra/httpd-userdir.conf
              # Real-time info on requests and configuration
              #Include conf/extra/httpd-info.conf
              # Virtual hosts (STE)
              #Include conf/extra/httpd-vhosts.conf
              # Local access to the Apache HTTP Server Manual
              #Include conf/extra/httpd-manual.conf
              # Distributed authoring and versioning (WebDAV)
              #Include conf/extra/httpd-dav.conf
              # Various default settings
              #Include conf/extra/httpd-default.conf
              # Secure (SSL/TLS) connections
              #Include conf/extra/httpd-ssl.conf
              # Note: The following must must be present to support
              #       starting without SSL on platforms with no /dev/random equivalent
              #       but a statically compiled-in mod_ssl.
              <IfModule ssl_module>
              SSLRandomSeed startup builtin
              SSLRandomSeed connect builtin
              </IfModule>
              NameVirtualHost 127.0.0.1
              <VirtualHost 127.0.0.1>
                      DocumentRoot "C:\wamp\www"
              </VirtualHost>
              Include "c:/wamp/alias/*"
              • 5. Re: Virtual Host (localhost) + Wamp 2.1
                Okay. Looks like your Documentroot is 'c:/wamp/www' .
                Try this:
                Go to <Directory "c:/wamp/www/"> tag.
                Comment out this line:  Deny from all
                Let me know if it helps.
                • 7. Re: Virtual Host (localhost) + Wamp 2.1
                  Please access the url with your IP address and not with localhost. Also check that you are able to browse that url from other machines in your network.
                  • 8. Re: Virtual Host (localhost) + Wamp 2.1
                    With reference to my previous reply, i assume that your document root is  'C:\wamp\www' where you have kept all the files. As suggested:
                    1. Find <Directory "c:/wamp/www"> in httpd.conf (Note your path may be different depending on your localhost path.)
                    A few lines below this you will see these lines:
                    Order Deny,Allow
                    Deny from all
                    Change Deny from all to Allow from All
                    and comment out (#) the Allow from 127.0.0.1 line.
                    2. Access all the urls with your MACHINE IP and NOT the localhost.
                    Let us know if this helps.
                    • 9. Re: Virtual Host (localhost) + Wamp 2.1
                      Make sure you restart the Wampserver and put it back online in case you have to make change in httpd.conf.
                      Also If you are getting 403 forbidden error, Please follow this wampserver  thread http://forum.wampserver.com/read.php?2,46857 which suggests to change 'Listen 80' to Listen 0.0.0.0:80 in httpd.conf.
                      • 10. Re: Virtual Host (localhost) + Wamp 2.1
                        Sytou34fr Level 1
                        No change.
                        Changes in the file are in bold and italics.
                        # directive.
                        #Listen 80
                        Listen  0.0.0.0:80
                        # Example:
                        User daemon
                        Group daemon
                        </IfModule>
                        </IfModule>
                        # features.
                        <Directory />
                            AllowOverride None
                            Order deny,allow
                            Deny from all
                        </Directory>
                        # below.
                            AllowOverride all
                            Order Deny,Allow
                        #   Deny from all
                            Allow from all
                        </Directory>
                        # is requested.
                        </IfModule>
                            Order allow,deny
                            Deny from all
                            Satisfy All
                        </FilesMatch>
                        # alert, emerg.
                        LogLevel debug
                            </IfModule>
                        </IfModule>
                            # Example:
                            # Example:
                        </IfModule>
                        </IfModule>
                            AllowOverride None
                            Options None
                            Order allow,deny
                            Allow from all
                        </Directory>
                        # text.
                        </IfModule>
                        # Some examples:
                        #EnableMMAP off
                        #EnableSendfile off
                        # necessary.
                        # Language settings
                        </IfModule>
                        #NameVirtualHost 127.0.0.1
                        #<VirtualHost 127.0.0.1>
                        #        ServerName localhost
                        #        DocumentRoot "C:\wamp\www"
                        #</VirtualHost>
                        NameVirtualHost 192.168.1.98
                        <VirtualHost 192.168.1.98>
                                ServerName 192.168.1.98
                        </VirtualHost>
                        • 11. Re: Virtual Host (localhost) + Wamp 2.1
                          Since you are able to access other sites, it should not be an issue with Edge Inspect. httpd.conf looks okay provided you place all your files inside document root ( c:/wamp/www ).
                          Please note, Edge Inspect will not be able to access a page if that url is not browsable on devices. You can also check out with WAMP forums.http://forum.wampserver.com/list.php?2
