Hello!
I am attempting to use the Internal Server Reporting feature in Captivate 7, and seem to have run up against a brick wall.
I set up the Wamp server just fine, and am able to see localhost.
I copy the two files internalServerReporting.php and internalserverread.php into a folder in the www directory of the wamp install.
I set the same location inside the quiz reporting element of Captivate, and turn on Quiz Reporting. The "Post Results" button appears inside the Captivate Program (see screenshot 1).
However, when you take the quiz (on the same machine), on completion, the "Post Results" button does NOT show (see screenshot 2).
Instead, after submitting the last question, you are prompted to fill in the Name and E-mail box.
If you do so, and click send, no other message is given. You are taken back to the results screen, with the only options being to "Continue" or "Review".
While the CaptivateResults folder is generated, there is nothing inside the folder.
I'm sure I'm missing something, but can't guess as to what it is.
I am running Captivate 7.0.0.118 64 bit, on a Windows 7 64 bit machine.
Any insights would be appreciated.
***** UPDATE****
It seems that this feature WILL work for me when publishing as HTML 5, but NOT when publishing as .swf. Is this a normal behavior, or are my Flash player installs / permissions messed up?
Message was edited by: scotta73
