4 Replies Latest reply on Sep 9, 2013 6:30 AM by rlegs09
    Multiple Check Boxes but only select one
    rlegs09
      I need to create a PDF form that uses three check boxes to show / hide three separate text fields. Each check box needs to toggle the field on and then off and only one check box can be checked at a time. I am stumped and need help. thanks.
        • 1. Re: Multiple Check Boxes but only select one
          To create a check-box group that works like a radio-button group you need to give them the same name, but different export values.
          To implement the show/hide fields functionality you'll need to use a script (attached to the MouseUP action of each check-box), which should look something like this:
          if (event.target.value=="Value1") {
               this.getField("Field1").display = display.visible;
               this.getField("Field2").display = display.hidden;
               this.getField("Field3").display = display.hidden;
          } else if (event.target.value=="Value2") {
               this.getField("Field1").display = display.hidden;
               this.getField("Field2").display = display.visible;
          etc.
          • 2. Re: Multiple Check Boxes but only select one
            rlegs09 Level 1
            Thanks that works a treat. One issue though is once a selection has been made and then the box is unclicked, the last text field remains visible. I have set it to hidden.
            • 3. Re: Multiple Check Boxes but only select one
              At the end of your code add something like this:
              } else  {
              • 4. Re: Multiple Check Boxes but only select one
                rlegs09 Level 1
                Top stuff!!
                Solved all of my problems. Thanks so much
