3 Replies Latest reply on Sep 10, 2013 3:50 PM by CHBedford
    Coldfusion 9 syslog setup
    cura_techops
      What exactly does this setting do in the CF admin configuration under the "Logging Settings" section?
        • 1. Re: Coldfusion 9 syslog setup
          CHBedford
          On unix, there are syslog facilities provided by various tools, such as syslog or nsyslog.  They listen on port a network port as well, but on the local host, a named pipe is provided for simplicity.  This service logs all the messages sent to it to files in /var as configured by the syslogd.conf file in /etc.
          For more information consult your unix man pages.
          -- Charles
          • 2. Re: Coldfusion 9 syslog setup
            cura_techops Level 1
            Thanks, yes I am familar with syslog on unix. So I enabled that feature in the CF admin page. Where should I be seeing logs under /var/log? Is CF sending everything over a named pipe? I assume there is setup I need to syslogd.conf unless CF logs to the /var/log/messasges file?
            • 3. Re: Coldfusion 9 syslog setup
              CHBedford Level 1
              I usually debug that kind of stuff with a *.* in the syslog.conf file and put that into a file like /var/log/all.log.  Once I know which messages I want to keep I adjust accordingly.
              -- Charles
