2 Replies Latest reply on Sep 9, 2013 6:51 PM by johndaigle
    New expanding hotspot character style doesn't get aplied
    kdws
      I have created my own .css file and have changed the expanding hotspot character style. When I create the expanding hotspot using DHTML> create expanding hotspot (or something like that, don't have the app in front of me because it doesn't run on a Mac {what's up with that?}) my expanding hot spot character style doesn't get applied. Instead, the normal style gets applied.
      I have to use the style drop-down box to get it to apply which doesn't make sense because it's not a paragraph style.
      Can't figure out how to say "Expanding hot spot, use the expanding hot spot character style"
        • 1. Re: New expanding hotspot character style doesn't get aplied
          johndaigle Level 4
          Here's something to try. It might be that an embedded style is overriding your external style sheet.
          As an example, when you import a Word document, Word's conversion process creates an Embedded Style for the A:link.
          This can defeat or override the character style you create for the expanded hotspot.
          In the (X)HTML Editor View look for this right above the closing </head> tag.
          <style type="text/css">/*<![CDATA[*/
          body {
                    background-color: #ffffff;
          A:visited {
                    color: #800080;
          A:link {
                    color: #0000ff;
          /*]]>*/</style>
          </head>
          If this is the case, just delete everything from "<style type" all the way down to and including "</style>"
          Just a thought.
          John Daigle
          Adobe Certified RoboHelp and Captivate Instructor
          Evergreen, Colorado
          www.showmethedemo.com
          • 2. Re: New expanding hotspot character style doesn't get aplied
            johndaigle Level 4
            BTW, if my previous post doesn't work. You might also try Format > Styles to open the Styles and Formatting pod. Then select Character styles from the dropdown. See if that allows you to more cleanly apply the character style.
