6 Replies Latest reply on Sep 10, 2013 12:24 PM by VideoGearHead
    Premiere CS5 - Project Monitor playback is jerky after resintall of operating system and CS5
    VideoGearHead Level 1
      PROBLEM: Premiere CS5 - Project Monitor playback is jerky
      This had NOT been an issue prior to reinstalling the operating system and all software.  I have read numerous articles on the forums and have tried everything I can find...with no results.
      I have scoured the articles here http://www.adobe.com/cfusion/search/index.cfm?loc=en_us&term=choppy%20video&cat=support&pr oduct=premierepro and others at Cretive Cow
      I have installed all updates for CS5 Master Collection, immediately following a fresh install of the operating system and SC5 Master Collection.
      I have ensured that sequence settings match resolution and frame rates of footage - the problem persists.
      I have tested by importing both standard def AVI files created from tape and high def SONY MP4 files - the problem persists.
      I have ensured the latest Video drivers are installed (clean installation selected, so that the Windows default would be removed) - the problem persists.
      I have tried the 3D settings in NVIDIA control panel | Program Settings tab... selected Adobe Premiere Pro from the drop down menu | and chaged 'Multi-display/mixed-GPU acceleration from the value of 'Multiple Display performance' to the value of 'single display performance'; although, I ran two monitors before using this latest NVIDIA video driver and I didn't experience this jerky footage issue - the problem persisted after affecting that change; so, I switched it back.
      Since I have 96 GB of RAM, I don't use a pagefile.  A zero MB page file is the same setting I had prior to rebuilding the C:  Regardless of whether I have a pagefile or not, the problem persists.
      I have tried creating a fresh user profile, where the user profile is created on the C: drive by default; and, where I left it there on C: to test for the jerky playback in a new PrPR project  - the problem persists.
      Regarding the C: (system drive) and why I reinstalled everything, it had become unstable and was locking up.  I ran DISK ERROR CHECKING with the FIX parameter and the system was still locking up on me.  Keep in mind that the System drive is a solid state drive.  Anyhow, I had no choice but to dive in and reinstall everything.  I wiped the system partition of the SSD using quick format and started installing the operating system.  Now, I've read the CLAIM that this cuases performance issues; but, the only place I see issues is in the video monitor playback in PrPr.  Everything else - Office applications...printing...browsing the Internet...works just fine, everything is responsive, whereas, I couldn't do ANYTHING with it before.
      The Operating system and all software is installed on C:
      All data files and most profile related folders are stored on D:
      C:\ (one Intel Solid State Drive - SYSTEM DRIVE)  Used Space: 57.5 GB  Free Space: 388 GB
      D:\ (four Western Digital 2TB drives in an on-board INTEL hardware RAID5 array & hotswapable backplane) used space: 1.28 TB Free space: 4.16TB
      Adobe Premiere Pro CS5 VERSION: 5.0.3 (005 (MC: 218798))
      Operating System    Microsoft Windows 7 Ultimate Version    6.1.7601 Service Pack 1 Build 7601
      System Manufacturer    Intel Corporation
      System Model    S5520SC
      System Type    x64-based PC
      Video    NVIDIA Quadro FX 4800 driver v.320.78
      Display        Dell 27" LCD (DisplayPort)
      Processor    Intel(R) Xeon(R) CPU           X5680  @ 3.33GHz, 3326 Mhz, 6 Core(s), 12 Logical Processor(s)
      Installed Physical Memory (RAM)    96.0 GB
      Page File Space    0 bytes
      Monitor PAUSE RESOLUTION: Full
      (regardless of this setting, the problem persists)
      Installed RAM: 95.9 GB
      RAM reserved for other applications: 10 GB
      Optimize rendering for: Performance
      (Changing this setting to 'memory' does not resolve the problem)
      Media Cache Files
      X - Save Media Cached files next to originals when possible
      (User Profile folders were relocated to D:\ from within the properties of each folder's 'LOCATION' tab.  This is the same configureation I had prior to rebuilding the C:\drive.  Testing under a new profile where it's allowed to stay on teh system drive does NOT resolve the problem.)
      Media Cache Database
      Scratch Disks
      Path: D:\Users...\My Documents\
      Video Rendering and Playback: Mercury Playback Engine GPU Acceleration
      (Setting Viideo Rendering and Playback to 'Sofware' does not resolve the problem)
      If any of y'all have any other suggestions, I'm all ears.
      Thank you.
