2 Replies Latest reply on Jan 7, 2008 11:46 AM by rossimo
    CuePoints Nav and Events Question
    rossimo Level 1
      I have one FLV with cuePoints assigned during encoding. I need the FLV to stop play at a specified cuePoint and jump to a navigation screen set-up in my timeline. Then from that screen in my timeline, the user needs to dictate where the playhead picks up in the FLV according to their selection.
      I would like to do this in AS 2.0, but will go with AS 3.0 if that is the best route.
      Any and all help is much appreciated!-
        • 1. Re: CuePoints Nav and Events Question
          RossRitchey Level 4
          You are looking for a cuePoint event listener.
          When using the FLVPlayback component, a cuePoint event is fired every time the playhead reaches a cuePoint.
          var listener:Object = new Object();
          listener.cuePoint = function(evt:Object){
          //do my actions in here
          As for dictating where the playhead starts up again, there is a seek() function in the video class
          Obviously, myFLVPlayer needs to be swapped with your FLVPlayback instance name, and time is a number that you can change to your variable, or hardcode numbers.
          • 2. CuePoints Nav and Events Question
            rossimo Level 1
            Thank you very much! I will try that out right now.
            Ritchey, I am looking for a sub-contract/freelance Flash Programmer. Is this something you do? If so, lets get in touch. Send me a PM with your contact information.
            EDIT: I was checking on my PMs and noticed that Abobe Forums default set-up has PMs disabled. I have enabled my PMs. If you tried to PM me and it didn't work, try again.
            Going to try your suggestions now. Thanks again and I look forward to getting a PM from you,
