0 Replies Latest reply on Sep 11, 2013 7:42 AM by techzol
    Adding Keyboard Shortcut when creating a new menu item via script
    techzol
      I've come across a very nifty script for adding Close All to the File menu; and with a few simple modifications, create a Save All script, too.
      What I cannot seem to find is a way to add a keyboard shortcut so that I can invoke it with a couple of keystrokes (other than Ctrl-Alt-Shift W or S, which is already built in, but awkward to press 4 keys at once).
      Alternative, a menu short cut be nice, so, just as you can do Alt-F-S to save a file, it would be nice to be able to do something like Alt-F-B to do a save all.
      The ID6 scripting tutorial seems to indicate the the former is not possible (page 5). But I can't seem to find anything about the latter.
      Does anyone have any thoughts or suggestions. Below is the script.
      /*   FileCloseAll.js                              */
      /*   Add a "Close All" feature in the File menu   */
      #targetengine "FileCloseAll"
      // THE MAIN PROCESS
      var fcaTitle = "Close All";
      var fcaHandlers = {
          'beforeDisplay' : function(ev)
              ev.target.enabled = (app.documents.length>1);
          'onInvoke' : function()
              var doc;
              for( var i = app.documents.length-1 ; i>=0 ; i-- )
                  doc = app.documents[i];
                  doc.close();
      // THE MENU INSTALLER
      var fcaMenuInstaller = fcaMenuInstaller||
      (function(mnuTitle,mnuHandlers)
      // 1. Create the script menu action
      var mnuAction = app.scriptMenuActions.add(mnuTitle);
      // 2. Attach the event listener
      var ev;
      for( ev in mnuHandlers )
          mnuAction.eventListeners.add(ev,mnuHandlers[ev]);
      // 3. Create the menu item
      var fileMenu = app.menus.item("$ID/Main").submenus.item("$ID/&File");
      var refItem = fileMenu.menuItems.item("$ID/&Close");
      fileMenu.menuItems.add(mnuAction,LocationOptions.after,refItem);
      return true;
      })(fcaTitle, fcaHandlers);
