Please share your PDF/UA-compliance experiences
a C student Sep 11, 2013 12:01 PMI encourage others to share your experiences in remediating PDFs for ISO 14289 (PDF/UA) compliance. Let’s learn from each other’s experiences.
I am working with documents that previously passed the Acrobat checker and PAC 1.3 along with manual checks for WCAG 2.0 compliance – so, the documents were as accessible as I knew how to make them. Below are the errors that I am seeing quite a bit from the new PAC2 PDF/UA-compliance checker. The “fix” is not necessarily the best, just what I have found that seems to work. I am using Acrobat Pro XI.
error: Font not embedded
fix: Tools > Print Production > Preflight > PDF fixups > Embed fonts
comment: This does not always work as some font licenses do not allow embedding. If you encounter non-embeddable fonts hopefully you have the source document and can use a different font.
error: Tagged content present inside an Artifact
fix: Open the Content pane. Open Artifact containers to find any content containers hiding inside. Drag the content containers to their proper place outside the Artifact container.
error: Alternative description missing for an annotation
fix: Add alt text to link tags.
comment: This seems an odd error. Some links benefit from alt text but others are perfectly clear without it. Seems like this should be a judgment call, but the Matterhorn Protocol insists on links having alt text.
error: Figure element on a single page with no bounding box.
fix: This error goes away if I tag the figure as an artifact, which makes sense. But if I then retag it as a figure and add back in the alt text, the error stays away.
comment: Seems odd. Even the Matterhorn Protocol PDF (http://www.pdfa.org/wp-content/uploads/2013/08/MatterhornProtocol_1-0.pdf) fails PAC2 on this point! This could be a rough spot in the PAC2 beta, not a real error, but is easy enough to “fix”.
error: DisplayDocTitle key is not set to true
fix: File > Properties > Initial View tab > In the Show drop down box, select “Document Title”
error: PDF/UA identifier missing
fix: Create an xmp file that includes the required snippet of metadata (example: http://bygosh.com/files/pdfuaid.xmp). Then: File > Properties > Description tab > Additional Metadata... > Advanced > Append
comment: This should be the final remediation step, after the document is otherwise PDF/UA-compliant. To apply the PDF/UA ID to a document that is not compliant would be fibbing.
