3 Replies Latest reply on Feb 23, 2014 8:20 AM by David_Powers
    no insert tab
    carratef
      I have Creative Cloud and in going through this tutorial for Dreamweaver, I've found that I do not have an insert tab and can't figure out where else it might be.  Any thoughts? Suggestions?
      Thank you!
        • 1. Re: no insert tab
          David_Powers Level 7
          If you can't see the Insert panel, go to the Window menu, and select Insert.
          • 2. Re: no insert tab
            Sinuhe
            I go to the Window menu ("ventana" in Spanish) and selected "Insert" (it adds or deletes a checkmark) and this has no effect on the right hand side, where my panels appear. It has an effect on the top bars, where I see the tabs: "Coomon", "Design", "Forms", etc. I can see the "div" element at the "Common" and "Design" tabs. But I cannot find the "Header" item, as instructed in the video.
            I am using the "Classic" display.
            Please help me!
            • 3. Re: no insert tab
              If you are using the Classic display, you're using Dreamweaver CS6 or earlier. The Classic display doesn't exist in Dreamweaver CC.
              Since you have Creative Cloud, you should be able to download and install Dreamweaver CC. Both versions can exist on the same machine (although they can't be used simultaneously).
