i need to call atleast 3 javascript functions in a form
using "onSubmit" works fine with one function but when i try to add another nothing happens....
<cfform
action="postpage.cfm" method="POST"
target="_self"
onsubmit="if(document.getElementById('Agree').checked) { return true; } else { alert('You must agree to the Terms and Conditions'); return false; }">
"return checkEmail(this);" is one of the funtions. it checks to see if 2 cfinputs are the same
how do i add multiple functions to onSubmit
tnx in advance
ColdFusion is simply behaving as it should. You will notice that the script that currently runs upon onSubmit ends in a return-statement. That signals the end of the event-handler.
If you wish to check the e-mail as well, you could run one script that performs both functions. I was thinking of something like the following, just off the cuff
onsubmit="if(!document.getElementById('Agree').checked) {alert('You must agree to the Terms and Conditions'); return false; } else {return checkEmail(this);}">
