3 Replies Latest reply on Jan 10, 2008 12:35 AM by chris.huston.t10
    Air Styles
    jbuda
      Hi
      I have downloaded and installed Flex 3 on my Intel Mac.
      I have copied the code to create my first application for air, but nothing seems to be working correctly.
      When i test it with the debugger, im getting no errors but the window is not transparent, and anything i do t the style seems to have no effect on the applciation window.
      <mx:WindowedApplication xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" title="Hello World">
      <mx:Style>
      Application
      background-image:"";
      background-color:"";
      background-alpha:"0.5";
      </mx:Style>
      <mx:Label text="Hello AIR" horizontalCenter="0" verticalCenter="0"/>
      </mx:WindowedApplication>
      the above is the code that im trying to use
        • 1. Re: Air Styles
          jbuda Level 1
          can anyone see an error in the code?
          This is a simple app that wont even compile properly.
          I have tried other projects that have been downloaded from the adobe website, but none of them seem to work...
          Anyone?
          • 2. Re: Air Styles
            rinse Level 1
            Maybe post in the AIR forum... people there might be able to help you better.
            • 3. Re: Air Styles
              chris.huston.t10 Level 3
              For transparency, you need to change the settings in your Application Descriptor File Template, which is the xml file in your src dirctory. The name is 'your app name + -app.xml'. Set the below two tags and you should get a transparent window.
              <systemChrome>none</systemChrome>
              <transparent>true</transparent>
              Keep your code as you have it. You just need to edit the Descriptor File.
              Vygo
