0 Replies Latest reply on Sep 12, 2013 8:13 AM by WJosset
    Data Binding Value ('$.) does not correspond to a data connection
          I have a form with an existing data connection to a schema and I want to change the connection to a different schema. After I change the connection, I receive error messages that the data binding value does not correspond to a data connection. I then go into the Binding Tab and set the binding using the 'Data Connection' to the element in the new schema. I then receive the error message, "Direct binding references to multiple levels of repeating data may not produce desired results. Form may require relative binding references for repeating subform containers.". Would anyone know what these errors are referring to? I'm not sure where I have gone wrong on the connection.
