4 Replies Latest reply on Sep 12, 2013 2:06 PM by millerjudi
    Need help with javascript used to check for data in required radio button fields
    millerjudi
      required_fields
      I keep getting a syntax error (SyntaxError: missing : after property id 17; at line 18).  I'm trying to run a script to check for data in all the required radio button fields before letting the user submit the form (or save it).  Here's the code I'm using:
      var AllRequiredFieldsSet = true;
      for(var i=0; i<this.numFields;i++)//loop through all form fields
                     var fldName=this.getNthFieldName;
                     var currentFld= this.getField(fldName);
                     if(currentFld.type=="radio")
                                    //All radios are required so see if user filled them out
                                    if(currentFld.value=="Off")
                                                   AllRequiredFieldsSet = false;//one of the radio buttons has not been selected so form can't be submitted
      if (AllRequiredFieldsSet==false)
                     app.alert("All required fields have not been completed");
      else
      this.submitForm({cURL "mailto:EMAILADDRESS@gmail.com", cSubmitAs: "PDF"});
      I'm not missing any brackets...Any ideas as to what I'm missing?
      Thanks! Judy
