1 Reply Latest reply on Jul 26, 2006 3:58 PM by jvroom
    Pagination in data service not working
    zax555
      Objective is to show a predefined number of records from the database and
      Populate a datagride.Say there are 50 records in the database and the
      requirement is to show 10 at time. As per documentaion JavaAdaper needs to be used with page size defined. Tried but it always return all the rows.
      Code:
      Mxml file
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns="*" pageTitle="Contact Manager" creationComplete="initApp()">
      <mx:Script>
      <![CDATA[
      import samples.contact.*;
      [Bindable]
      public var contacts:ArrayCollection;
      [Bindable]
      public var contact:Contact;
      private var ds:DataService;
      private function initApp():void
      var i:int;
      contacts = new ArrayCollection();
      ds = new DataService("contact");
      ds.pageSize=4;
      ds.autoCommit = false;
      ds.fill(contacts);
      AsyncToken(ds.fill(contacts));
      token.kind = "fill";
      </mx:Script>
      <mx:DataGrid id="dg" dataProvider="{contacts}" width="100%" height="100%" change="contact=Contact(dg.selectedItem)" editable="true" >
      <mx:columns>
      <mx:DataGridColumn dataField="contactId" headerText="Id"/>
      <mx:DataGridColumn dataField="firstName" headerText="First Name"/>
      <mx:DataGridColumn dataField="lastName" headerText="Last Name"/>
      </mx:columns>
      </mx:DataGrid>
      Flex-data-service.xml
      <destination id="contact">
      <adapter ref="java-dao" />
      <properties>
      <source>samples.contact.ContactAssembler</source>
      <scope>request</scope>
      <metadata>
      <identity property="contactId"/>
      </metadata>
      <network>
      <session-timeout>2</session-timeout>
      <paging enabled="true" pageSize="10"/>
      <throttle-inbound policy="ERROR" max-frequency="500"/>
      <throttle-outbound policy="REPLACE" max-frequency="500"/>
      </network>
      <server>
      <fill-method>
      <name>loadContacts</name>
      </fill-method>
      <fill-method>
      <params>java.lang.String</params>
      </fill-method>
      <sync-method>
      <name>syncContacts</name>
      </sync-method>
      </server>
      </properties>
      </destination>
        • 1. Re: Pagination in data service not working
          jvroom Level 1
          This all looks ok to me. If the data grid is displaying all 50 rows, you will see all 50 and might not notice that it was actually fetching them 10 rows at a time. To see more about what the server is sending to the client, enable the debug logging in the server. Go to your services-config.xml (in WEB-INF/flex) and search for "level=". Change that to Debug and make sure your <pattern> tags just below that include both "DataService.*" and "Message.*". When you run the application, you should see something like:
          [Flex] [DEBUG] Before invoke service: data-service
          incomingMessage: Flex Message (flex.data.messages.DataMessage)
          operation = fill
          id = null
          clientId = 5BA19DE7-635A-5F00-819D-AD0AEB206647
          correlationId =
          destination = contact
          messageId = E6389592-D861-9753-1792-AD0AEB20638E
          timestamp = 1153954409497
          timeToLive = 0
          body =
          hdr(DSEndpoint) = my-rtmp
          hdr(pageSize) = 4
          and then:
          [Flex] [DEBUG] After invoke service: data-service
          reply: Flex Message (flex.data.messages.PagedMessage)
          sequenceId = 0
          sequenceSize = 13
          (no sequence proxies)
          clientId = null
          correlationId = null
          messageId = F27873A5-264C-C0AC-E9E3-C625EE3FEA61
          timestamp = 1153954430598
          timeToLive = 0
          body =
          [contactId=3, firstName=Randy, lastName=Carter, address=, phone=555-555-55
          55, zip=],
          [contactId=12, firstName=Mary, lastName=Connors, address=, phone=, zip=],
          [contactId=5, firstName=Pierre, lastName=Dupont, address=, phone=222-222-2
          222, zip=],
          [contactId=7, firstName=Jose, lastName=Espinosa, address=, phone=, zip=]
          operation = page
          id = null
          clientId = C406259D-7A45-269E-CB51-AD0B3E282DE1
          correlationId =
          messageId = F3E58955-27D9-8AF9-5A7C-AD0B3EC48421
          timestamp = 1153954430722
          timeToLive = 0
          body = {}
          hdr(sequenceId) = 0
          hdr(pageIndex) = 1
          hdr(pageSize) = 4
          sequenceId = 0
          sequenceSize = 13
          clientId = null
          messageId = F27874D3-E208-C26D-A448-B9AFE682B86D
          timeToLive = 0
          body =
          [contactId=10, firstName=Luis, lastName=Fernandez, address=, phone=, zip=]
          [contactId=15, firstName=Paula, lastName=Green, address=, phone=, zip=],
          [contactId=11, firstName=Chloe, lastName=Jones, address=, phone=, zip=],
          [contactId=9, firstName=Zoe, lastName=King, address=, phone=, zip=]
          Notice that there is first a "fill" message which returns 4 rows, then a page message which returns the next 4 rows. Try making your initial window smaller and hit "refresh" and then you should only see those page messages go across when you scroll.
