2 Replies Latest reply on Sep 13, 2013 11:21 AM by deckard2013
    Copy text from table to table issue
      Using CS6 on PC Win 7 64bit
      not noticed this before probably becasue I usually copy in from Excel or Word docs, but when I copy text from one table to another in a document  its copying it as a nested table,
      if I just copy a single  cell then thats ok but anything else its placed as a table within the target table.
      Probably something really obvious I've overlooked, but its driving me nuts
      Have looked in  prefs and Clipboard  is set for just text, apart from that I cant see anything
      thanks for any help you can give
        • 1. Re: Copy text from table to table issue
          BobLevine MVP & Adobe Community Professional
          If you copy 5x5 cells you need to select 5x5 in the destination.
          • 2. Re: Copy text from table to table issue
            deckard2013 Level 1
            Hi Bob
            thanks for that speedy reply.
            I've just been doing some testing and I'm not sure if the results I'm getting are how things should be.
            I just called up one of my recent excel tables and did what I usually do, highlight from the top left cell to the bottom right hand corner cell, Ctrl-C
            Excel table is always 11 column but  the number of rows varies from week to week, from 50 or so to 250.
            Opened an ID table  template I use which width wise is  the same amount of columns as my source excel file 11 columns, but only a few rows.
            Place the cursor and highlight the first row in ID  Ctrl-V,  table is filled and it auto inserts more rows to the limit of the object box  and then I just drag the table down to fill the page and then just click and drag the loaded cursor to create more table space on the next page if needed, nice and simple.
            Just opened a new  table with 6 rows and 4 columns
            and tried to paste into a table with 2 rows and 4 columns expecting it to automatically fill and give me the overfill red icon on the frame but it doesnt
            but it does with text from outside of ID, I just tested it, it automatically fills all the table and adds rows until the object fram is ful and then I can just use the overfill facility to increase the table size
            Seems odd that this only works with externally copied material
