1 Reply Latest reply on Jan 8, 2008 3:11 PM by Tigomark
    The mighty caching debate
    Tigomark Level 1
      Is there a way to write an action script that will make sure that caching is set to zero.
      I handle caching in my php script
      [CODE]
      header("Expires: Mon, 26 Jul 1997 05:00:00 GMT"); // Date in the past
      header("Last-Modified: " . gmdate("D, d M Y H:i:s") . " GMT"); // always modified
      header("Cache-Control: no-cache, must-revalidate"); // HTTP/1.1
      [/CODE]
      however the flash player seems to not respect the caching script and thus the information outputed does not update.
        • 1. Re: The mighty caching debate
          Tigomark Level 1
          Ok this whole thing goes to the fact that I never reset the list in
          the first place.
          So what I need to do is take the list
          Code:
          private function resetForm():void{
          tempXML.asset = false; //clear it I could also us tempXML.asset =
          newXMLListCollection(tempXML.asset); either way it clears it
          tempXML.asset = tempXML.asset; //redisplay it
          This will definatley clear out the old list but now I need a way to
          recall the same list from the
          Code:
          <mx:XML id="tempXML"
          source="https://mysite.net/interface.php?action=showopen&amp;operation=showasset\
          s&amp;format=xml&amp;opstatus=defect"
          and I'm not quite sure how to do this
