1 Reply Latest reply on Sep 13, 2013 1:42 PM by W_J_T
    Is there an Illustrator script that exports multiple file formats at the same time?
    CurtisBillue
      I've found some very good scripts like the MultiExporter.js by Matthew Ericson and Export Layeres as PNG files by Johan Otterud, however none that quite fit our needs. We need an Illustrator script that takes an AI file and spits out an .eps, .jpg (for print), multiple .png sizes for web, and .pdf. We have an extensive download library for members that constantly change and rotate with new logos, print materials and other graphics.
      I was hoping that there was some kind of script that would cut some time off of exporting all the different versions each time. If anyone knows where I should look, then please let me know. Thanks, Curtis
        • 1. Re: Is there an Illustrator script that exports multiple file formats at the same time?
          W_J_T Level 4
          cbillue2 wrote:
          - Is there an Illustrator script that exports multiple file formats at the same time?
          - We need an Illustrator script that takes an AI file and spits out an .eps, .jpg (for print), multiple .png sizes for web, and .pdf.
          I personally don't recall seeing such a script that does all those things simultaneously, however you can find examples of each (like the few you have already discovered) as a starting point for creating such a script. If you search, here or elsewhere along with reading the scripting documentation and the examples provided in there you should find everything you need to get started and accomplish such a script.
