12 Replies Latest reply on Sep 16, 2013 7:39 AM by Ellis home
    Duplex Printing
    Roy E
      I am running InDesgn CS5 on an iMac (OS10.6) and printing to a Brother (duplex) printer. The printer has printed duplex from other programs. But I can not get it to, or figure out how to get it to, print duplex from InDesign. How does one do this?
        • 1. Re: Duplex Printing
          Ellis home Level 4
          Do you mean after setting duplex in printing preferences in Print/Set Up it doesn't work? Have you tried exporting to PDF and printing from there?
          • 2. Re: Duplex Printing
            Roy E Level 1
            Ellis,
            When you say "setting printing preferences in Print/SetUp" are you reffereing to Apple Peferences or InDesign Preferences? I have looked at and trough both, but find no option for duplex printing? I have tried printing from pdf, but have the same difficulty. I have searched the web and find mu difficulty mentioned/discussed, but lttle concrete help. Tried Adobe chat, but was told "Sorry Charlie" CS 5 is not the current software. Help. please?
            • 3. Re: Duplex Printing
              Ellis home Level 4
              In Indesign, with your document open, you go to File/Print and at the bottom you see Set up, that will get you to your printer and there you can choose duplex. When I did it in my HP printer it worked but I'm on Windows.
              • 4. Re: Duplex Printing
                Roy E Level 1
                On the iMac  when I go to File > Print I have five options: Page Set Up, Printer, Save Preset, Cancel, Print. When I go to page Set Up or Printer I have no option for Duplex or a similar option. I tried Adobe chat, but was shot down -- they no longer support CS5 unless you purchase a contract -- and they won't say whether there is any help available.
                • 5. Re: Duplex Printing
                  Ellis home Level 4
                  Well, hopefully someone using Mac will show up to see if we can help you. But, you mean you don't get this Print screen:
                  • 6. Re: Duplex Printing
                    Roy E Level 1
                    I get a similar screen, but no optin I can identify as dulpex pringing/print back to back, etc .
                    • 7. Re: Duplex Printing
                      Ellis home Level 4
                      OK, just to make sure we are talking about the same thing here. You want to print on both sides of the page, is that right?
                      • 8. Re: Duplex Printing
                        Roy E Level 1
                        Absolutely. That is why I bought the Brother HL-5470DW printer -- but so far its been a bust. I write books. The current one is 500 plus pages and I really need to do duplex. I appreciate all your input/help very much.
                        • 9. Re: Duplex Printing
                          BobLevine MVP & Adobe Community Professional
                          If you're having the same issues from Acrobat I would contact Brother about
                          updated drivers.
                          • 10. Re: Duplex Printing
                            Ellis home Level 4
                            Besides Bob's recommendation, what do you get when you click on Setup in the Print screen. This is what I get:
                            As you can see my default printer HP LaserJet 4200 is selected and when I click on Preferences it will take me to my printer's options. Don't you see something similar when you click on Setup?
                            • 11. Re: Duplex Printing
                              Roy E Level 1
                              A thank you to all who pitched in. The problem has been solved. I am not certain just how as I was taking the advice offered and at the same time trying things on my own. Not the best trouble shooting strategy. I went to Brother to up date the drivers, but apparently had their latest for this printer. I change the Brother printer to the default printer and shut the iMac down for the night. Then in the morning I followed the path laid out by Ellis (again) making allowances for the somewhat different menus. And I found the two-sided option. As there are more than a few inquiries on the Internet about this issue I have laid out the following that may help others. i) Check for driver updates. ii) If not already done set your duplex printer as your default printer; iii) Shut down your Mac and let it sit for at LEAST a couple of minutes. iv) On restart open the relevant document and go to: File > Printer. When the printer window opens: v) Check for the correct printer and if necessary select it. Set the available parameters – pages, setup, etc. vi) Then click the Printer button at the bottom of the Print Window-not the Print Button, but the PRINTER Button.
                              vii) This opens a second Print Window. Click the Two Sided box. viii) Click the Print Button which closes the window.
                              ix)  Click the Print button on the first window.
                              The difficulty I was having was that when I got to the second window (above) I had the same two options I had on the firlst window - Collate and Reverse order. Now I get the "right" options! Again a thnak you!
                              • 12. Re: Duplex Printing
                                Ellis home Level 4
                                Great. I'm glad you sorted it out. And thanks for sharing your experience so other users may benefit from it.
