1. Re: Editing with 4k MXF files..CPU or GPU?
joe bloe premiere Sep 14, 2013 5:18 PM (in response to lou4uandme)...upgrade my 7 year old system.
A lot has changed in the last seven years.
Adobe Premiere Pro CS6 / CC Tech specs
http://www.adobe.com/products/premiere/tech-specs.html
Optimizing for performance: Adobe Premiere Pro and After Effects
2. Re: Editing with 4k MXF files..CPU or GPU?
lou4uandme Sep 14, 2013 5:21 PM (in response to joe bloe premiere)Yeah Ive been editing with my 6600 quadcore/ 6 ram system. So before I spend money on the wrong items, i want to be clear.
3. Re: Editing with 4k MXF files..CPU or GPU?
joe bloe premiere Sep 14, 2013 5:26 PM (in response to lou4uandme)There's a Forum perfect for you:
4. Re: Editing with 4k MXF files..CPU or GPU?
JSS1138 Sep 14, 2013 6:07 PM (in response to lou4uandme)or a 6 core and a geforce card?
Definitely that.
5. Re: Editing with 4k MXF files..CPU or GPU?
JSS1138 Sep 14, 2013 6:07 PM (in response to lou4uandme)[Moved to Hardware forum.]
7. Re: Editing with 4k MXF files..CPU or GPU?
ECBowen Sep 16, 2013 1:38 PM (in response to lou4uandme)Both the CPU and the GPU are important with GPU acceleration. You do not require less CPU because of the GPU acceleration. The GPU acceleration actually requires better CPU processing to really push the GPU. This means you want an Ivy-E CPU and a 770GTX or Higher video card for that media. Also make sure you get 32GB of ram.
Eric
ADK
8. Re: Editing with 4k MXF files..CPU or GPU?
naumen Oct 20, 2013 7:16 PM (in response to ECBowen)its maybe going to be a bad news for you , BUT u DONT HAVE 4K files. Canon c300 at its max gives u just full HD - 1920x1080!!! so again u dont work with 4k files. C300 has a 4k sensor, but only Full HD. C500 on the other hand can give 4k externaly!
i use C300 my self
and i can tell that my I7 950 24GB ram , gtx 580 3gb, SSD on drive c , no raids .... works fine, but i plan to update to 6 core...
9. Re: Editing with 4k MXF files..CPU or GPU?
superjunilie Nov 20, 2013 7:56 AM (in response to lou4uandme)you mean to edit MXF Video on pc? Both the CPU and the GPU is ok.
