1. Re: script with Magic Wand tool ?
JJMack Sep 15, 2013 8:07 AM (in response to saigon80)I think you woul need to create a function from Scriptlistener code for the magic wand tool where your working with units pixels and you pass the x and y pixel values for the document center when you use the function. Something like
function MagicWand(x,y) {
var idsetd = charIDToTypeID( "setd" );
var desc425 = new ActionDescriptor();
var idnull = charIDToTypeID( "null" );
var ref134 = new ActionReference();
var idChnl = charIDToTypeID( "Chnl" );
var idfsel = charIDToTypeID( "fsel" );
ref134.putProperty( idChnl, idfsel );
desc425.putReference( idnull, ref134 );
var idT = charIDToTypeID( "T " );
var desc426 = new ActionDescriptor();
var idHrzn = charIDToTypeID( "Hrzn" );
var idPxl = charIDToTypeID( "#Pxl" );
desc426.putUnitDouble( idHrzn, idPxl, 583.000000 ); <------------- replace the hard coded 583 with var X
var idVrtc = charIDToTypeID( "Vrtc" );
desc426.putUnitDouble( idVrtc, idPxl, 332.000000 ); <--------------- replace the hard coded 332 with vat y
var idPnt = charIDToTypeID( "Pnt " );
desc425.putObject( idT, idPnt, desc426 );
var idTlrn = charIDToTypeID( "Tlrn" );
desc425.putInteger( idTlrn, 255 );
var idAntA = charIDToTypeID( "AntA" );
desc425.putBoolean( idAntA, true );
executeAction( idsetd, desc425, DialogModes.NO );
Also use your own Scriptlistener code make sure of the all setting used point sample size, only current layer, antialias, etc.
Message was edited by: JJMack
2. Re: script with Magic Wand tool ?
pixxxel schubser Sep 15, 2013 10:22 AM (in response to JJMack)@JJMack,
why you do not work with percent?
Give this line 13-17 (in your code) a chance.
var idPxl = charIDToTypeID( "#Prc" ); desc426.putUnitDouble( idHrzn, idPxl, 50 ); var idVrtc = charIDToTypeID( "Vrtc" ); var idPxl = charIDToTypeID( "#Prc" ); desc426.putUnitDouble( idVrtc, idPxl, 50 );
3. Re: script with Magic Wand tool ?
saigon80 Sep 15, 2013 10:48 AM (in response to JJMack)Thanks Mr.JJMack for your help ! I dont know much about scripts and fuction also . After some trials with your suggestion, it's worked !
also thanks schubser . Wish all you luck from Vietnam
4. Re: script with Magic Wand tool ?
JJMack Sep 15, 2013 10:42 AM (in response to pixxxel schubser)If you want to work and switch between units that is fine. I normally work with absolute pixels. When things are relative particularly percent you may stumble when finding a document orientation and aspect ratio for width is 100% and height is 100% is a square world NO!
6. Re: script with Magic Wand tool ?
Michael L Hale Sep 15, 2013 12:31 PM (in response to JJMack)To have better control over what is selected you need to add other arguments to the scriptlistener function.
function magicWand(x,y,tolerance,anit_alias,contiguous,sampleAll) { if(arguments.length < 2) return;// make sure have x,y - other arguments are optional if(undefined == tolerance) var tolerance = 32;// set defaults of optional arguments if(undefined == anit_alias) var anit_alias = true; if(undefined == contiguous) var contiguous = false; if(undefined == sampleAll) var sampleAll = false; var desc = new ActionDescriptor(); var ref = new ActionReference(); ref.putProperty( charIDToTypeID('Chnl'), charIDToTypeID('fsel') ); desc.putReference( charIDToTypeID('null'), ref ); var positionDesc = new ActionDescriptor(); positionDesc.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Rlt'), x );// in pixels positionDesc.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Rlt'), y ); desc.putObject( charIDToTypeID('T '), charIDToTypeID('Pnt '), positionDesc ); desc.putInteger( charIDToTypeID('Tlrn'), tolerance); desc.putBoolean( charIDToTypeID('Mrgd'), sampleAll ); if(!contiguous) desc.putBoolean( charIDToTypeID( 'Cntg' ), false ); desc.putBoolean( charIDToTypeID('AntA'), anit_alias ); executeAction( charIDToTypeID('setd'), desc, DialogModes.NO ); }; magicWand(100,100,10,true,true); -
7. Re: script with Magic Wand tool ?
JJMack Sep 15, 2013 1:30 PM (in response to Michael L Hale)The OP wanted (tolerance 255, anti alias , contiguous) as a constant he is trying to select a centered object where there are many objects on a single layer all surrounded by a transparent area. Still nothing was stated about sample size. If the sample size it a single point or small. I feel the magic wand may not select their whole center object.
8. Re: script with Magic Wand tool ?
saigon80 Sep 16, 2013 3:03 AM (in response to JJMack)You are right Mr. JJMack Your example may be not very often case that Red Blue and Green hue are completely saturated, and highly opposed. I guess. We can apply one more step in action to ensure a full selection : Select / Grow (tolerrance 255 ) without care sample size
